Konica c224 e can't access service mode
Thank you for payment.
Reset code for your machine:
MFP Serial Number ACVD042001626
Reset Code 8VXZH-RCXMD-TQTVQ-KL7MD-52AF8-CG8YD-ENJQG-YYDLV
If the code does not work, I will generate a new one. Codes unfortunately have an expiry date and this one was generated a few days ago.
Regards
Serial Number: ACVD042001626
MAC Address: 00:20:6B:FC1
4
CE Password Request Code: 7KX8U-BS27H-HC56A-YD8MS-6QF5N-CG8YD-ENJQ6-YYDJZAttached FilesComment
The machine needs to have the current date and time set.
A new request code is generated by the machine whenever the CE Password Reset procedure is started.Attached Files👍 1Comment
👍 1Comment
Hi again, a similar issue with another of the C266i. I would appreciate if a reset code is provided for this one, thanks
Serial Number: ACVD1420000187
MAC Address 00:20:6B:FC:78:33
CE Password REset Code F9MKP-GT9SF-J66YF-W9ZKC-EYPGC-9G8YD-ENJQ6-YYTDF
MFP Serial Number ACVD142000187
Reset Code GENMZ-PJWPD-ZWTGE-F2LM9-JYWR3-2G8YD-ENJQG-YYTHV
Thank you for your payment.
RegardsComment
