Konica c224 e can't access service mode
  • Profibastler
    • Nov 2014
    • 102
    #676
    Originally posted by jotunn
    Reset codes for your machines
    MFP Serial Number A5C4021154053
    Reset Code 55YUZ-LN77N-2JJGK-JRQXK-WQJ7G-KG8YD-ENJQG-UZDNH
    MFP Serial Number A5C2021047467
    Reset Code ZGWUR-9K39L-7CNZM-CQJJ9-DLK9J-2G8YD-ENJQG-UZDNH
    MFP Serial Number A5C4021201661
    Reset Code 9U6HX-C3UTQ-MHS3C-ZQGT9-RNFE5-CG8YD-ENJQG-UZDNF
    Donations welcome
    Regards
    Please help for input the new EC reset codes
    There`s no accepting new codes. After login in Service Mode again, request code will be change.
    Please tell right procedure.
    • khanzr
      • 7
      #677
      Thank you for payment.
      Reset code for your machine:
      MFP Serial Number ACVD042001626
      Reset Code 8VXZH-RCXMD-TQTVQ-KL7MD-52AF8-CG8YD-ENJQG-YYDLV
      If the code does not work, I will generate a new one. Codes unfortunately have an expiry date and this one was generated a few days ago.
      Regards
      You are right this one has expired, I have generated a new one now
      Serial Number: ACVD042001626
      MAC Address: 00:20:6B:FC14
      CE Password Request Code: 7KX8U-BS27H-HC56A-YD8MS-6QF5N-CG8YD-ENJQ6-YYDJZ
      Last edited by khanzr; 06-10-2025, 12:11 PM. Reason: upon a second try it got me to this request code now
      • jotunn
        • 635
        #678
        Try this one - it's based on request code from your screenshot:
        Reset Code 6AGXH-YX7A5-AJ9NF-Z8AEX-A99VN-2G8YD-ENJQG-YYTDB
        Regards
        • jotunn
          • 635
          #679
          Both request and reset codes are valid for no more than a week, so after over two weeks it's hard to expect that reset codes will still work.
          The machine needs to have the current date and time set.
          A new request code is generated by the machine whenever the CE Password Reset procedure is started.
          • khanzr
            • 7
            #680
            Regards
            Thanks it worked, I have another machine also with same problem. I shall get the details and send you the payment for it also
            • khanzr
              • 7
              #681
              Hi again, a similar issue with another of the C266i. I would appreciate if a reset code is provided for this one, thanks
              Serial Number: ACVD1420000187
              MAC Address 00:20:6B:FC:78:33
              CE Password REset Code F9MKP-GT9SF-J66YF-W9ZKC-EYPGC-9G8YD-ENJQ6-YYTDF
              • jotunn
                • 635
                #682
                MFP Serial Number ACVD142000187
                Reset Code GENMZ-PJWPD-ZWTGE-F2LM9-JYWR3-2G8YD-ENJQG-YYTHV
                Thank you for your payment.
                Regards
                • wacko_jacko
                  • Jun 2025
                  • 2
                  #683
                  Can I also ask for the code for my machine (Bizhub C368)? I've just done a donation via PP (my email: p....ski@gmail.com).
                  S/N: A7PV021207095
                  MAC: 00:20:6B:5B:2D:9E
                  CE Pass reset request code: E5722-V9QQ5-84ZXY-VBYD5-78AGE-2G8YD-ENJQG-YYTPP
                  This gallery has 1 photos.
                  • jotunn
                    • 635
                    #684
                    Thank you for donation.
                    MFP Serial Number A7PU021207095
                    Reset Code FH5KH-KZ4N9-HAA44-6VTRT-SVTDD-GG8YD-ENJQG-YYTTX
                    Regards
                    • wacko_jacko
                      • Jun 2025
                      • 2
                      #685
                      Sorry jotunn, looks like the code changed today.
                      • Zoran
                        • 52
                        #686
                        Hi
                        A7PU021008400
                        00:20:6B:A2:38:56
                        RSKCL-5YPWX-3CFDT-YS3JY-VXABT-CG8YD-ENJQG-QYTNB
                        A7AH127000434
                        00:20:6B:3A: D8:41
                        9ELA4-JHCPJ-4PYFT-DP3SX-CQRCV-9G8YD-ENJQG-YYTNL
                        • diewalge
                          • Jun 2025
                          • 1
                          #687
                          after replacing the ITB on C458 can't initiate "new release" because of missing PW...
                          Serial: A79W021003781
                          MAC: 00:20:6B:B9:72:80
                          CE Password Reset Request Code: JAE3G-Z9BEH-2XV5J-6PEJX-TQQAJ-CG8YD-ENJQG-YZDNZ
                          any help would be very appreciated!
                          Stefan.
                          • jotunn
                            • 635
                            #688
                            Stefan.
                            Replied via PM.
                            • Brad6784
                              • Mar 2015
                              • 84
                              #689
                              Hi Jotunn,
                              I hope you're well.
                              I wondered if I could again trouble you for some assistance please? I have a KM C250i with a changed CE password that I would be extremely grateful if you could help me with a reset code please.
                              You've provided me with a reset code for this machine before but at the time I had completely forgot I'd taken the fuser for another device in the field. By the time the fuser came in and I fitted it, obviously the reset code was no longer valid. Since then the machines been sitting in the corner of the workshop and I'm only now getting round to getting it sorted.
                              I've just sent 3x $5 for to your paypal, only you had helped me with this device and another machine at that time, so I thought it only fair I transfer 3x the donation amount.
                              I won't make this mistake again, I will enter the code upon receiving it.
                              Any help would be very much appreciated, thank you Jotunn.
                              Kind regards, Brad
                              • jotunn
                                • 635
                                #690
                                Originally posted by Brad6784
                                Hi Jotunn,
                                I hope you're well.
                                Kind regards, Brad
                                I'm doing well, thank you for asking. And of course, it's absolutely no trouble to help you out again, I'm happy to do it.
                                Thank you very much, the donation came through! I really appreciate the gesture, but please remember that help is always free for site contributors, so there's no need for that in future.
                                Here is the new reset code for your machine:
                                MFP Serial Number AA2M321003426
                                Reset Code CCCBE-NHBVT-9QRWJ-BQTSG-P48JT-GG8YD-ENJQG-4YDFX
                                All the best,
                                Jotunn​
