Konica c224 e can't access service mode
  • femaster
    • May 2011
    • 1526
    #586
    It's pretty ridiculous the number of people that need to reset the password. Makes me wonder what exactly is going on out there in the service world...
    • Synthohol
      Certified Konica Expert
      • 5908
      #587
      Originally posted by jotunn
      没有离职员工--机器被故意擦除以重置或更改计数器。此时,机器没有分配序列号,管理员模式和服务模式的两个密码都被随机值 覆盖。在这种情况下,该机器只能作为零件或废料处理。
      付款链接如下。付款后,将像往常一样生成重置密码。
      https://www.paypal.com/ncp/payment/SJZ64UU9KA4R4
      when you catch these jokers taking advantage of you, $50 is cheap.
      its crooks like that making it hard to volunteer your time and attention.
      i wouldnt blame you if you started charging everybody!
      • Duplicator
        • May 2022
        • 260
        #588
        What boggles my mind is the number people offering KM service without access to KM resources as a dealer. I know that isn't easy/cheap to get but...c'mon... Stuff like the service manual, firmware, and the ability to order parts from KM is almost critical to function in support.
        It seems like the copiers are designed around the idea that you MUST HAVE access to the service manual and bulletins to find some of the settings. Especially stuff like dip switches, and the engine switches. There are tons of hidden menus too.
        Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
        If I helped you out, please give me a thumbs up! It helps my reputation.
        • Bricorley
          • Jul 2017
          • 42
          #589
          bummer...same unit now throwing a machine type error. Confirmed type and attempted firmware. Failed on MFP. Had to do a MFP swap. May i ask for help again?
          Serial # A8JE0011005583
          MAC - 00:20:6B:F7:AD:1A
          CODE - V89DD DZGW6 UV62F ZQR3K 7ELUS WG8YD ENJQG EZDR7
          THANKS A TON FOR ALL YOUR HELP. WE ALL TRULY VALUE IT
          • jotunn
            • 637
            #590
            Please check again the data you sent - in particular the serial number. Preferably take a picture of the CE Reset machine screen.
            Regards
            • Bricorley
              • Jul 2017
              • 42
              #591
              Regards
              Went back and verified serial # on back of unit and under the meter count. ITs correct. I will GLADLY paypal you at the link you left the other day on another post. Attached is the reset screen you requested
              This gallery has 1 photos.
              • jotunn
                • 637
                #592
                Yes, I didn't expect this much traffic on this thread.
                All of this traffic comes from essentially four cases:
                - Mistakes made by ignoring procedures.
                - Experimentation.
                - "Stealing" clients from other services.
                - Side effects of illegal activities, such as manipulating machine counters.
                The first case is not as common as it might seem, despite the lack of access to documentation or parts.
                The second case is not very common either - rarely is someone willing to sacrifice a machine for knowledge.
                The third case is surprisingly common-though it's not entirely legal, small services try to protect themselves from competition by setting their own service passwords. In this case, if a customer visits a competing service, they are forced to contact you, which is a good opportunity to ask why they chose another service. This method can also protect against cheap, unauthorized services that lack access to documentation or proper tools.
                The fourth case has become increasingly popular recently, especially in Asia.
                Apparently $50 was enough to deter most.
                Originally posted by Duplicator
                What boggles my mind is the number people offering KM service without access to KM resources as a dealer. I know that isn't easy/cheap to get but...c'mon... Stuff like the service manual, firmware, and the ability to order parts from KM is almost critical to function in support..
                These are often service technicians who have worked for several years in smaller or larger service centers, where they gained knowledge and experience (including documentation and other necessary tools) and left their jobs to make money for themselves, not for someone. Used machines can be bought cheaply, original consumables can be bought off-the-shelf in many places, often at lower prices than dealers buying from Konica Minolta. If you want to play with non-OEM, you can skip the middlemen altogether and buy directly from China. Parts are also available - from used or damaged machines. And when you need something new in exceptional cases, you can always find a service that will sell it to you.
                • tsbservice
                  Field tech
                  • 8064
                  #593
                  So basically you are saying your help is going mostly towards 3rd and 4th cases. If so I would stop it immediately!
                  Don't get me wrong I'm all in helping other techs earn their money but they(crooks) kreep too damn easy here.
                  • jotunn
                    • 637
                    #594
                    Yes, the serial number is correct this time - the first time it had doubled "0" and I did not notice it. Sorry, I'm blind
                    MFP Serial Number A8JE011005583
                    Reset Code PBDX8-ZKDKA-F5D35-3Z2SH-HQE25-WG8YD-ENJQG-EZTDD
                    I don't even know if this link will work - I did it quickly to deter pests.
                    If you really want to try, here's the link for you, that will be enough
                    Best regards
                    • technics1210
                      • Oct 2020
                      • 16
                      #595
                      Hello,
                      I bought a used C368.
                      Unfortunately I can't get into the CE menu.
                      I don't have a password.
                      I don't currently need access to the menu. But it's always good to have all the passwords for a machine
                      Would you be so kind as to send me the reset code?
                      Thx.
                      Technics
                      Serial: A7PV021020615
                      MAC: 00:20:6B:B3:28:F4
                      Requesst Code: QZFML-EGV5H-57T9Z-4TX9U-AX8LN-SG8YD-ENJQG-EZDRT
                      • jotunn
                        • 637
                        #596
                        The third case seems acceptable. The customer is the owner of the machine (we're not talking about machines under contract), and he has the exclusive right to decide who services his machine. So in a perfect world, when the machine is delivered to the customer's premises, the customer should be asked to set his own service and administrative password. And all servicing should take place assisted by the customer's representative (data security, privacy issues, etc.).
                        But it's not a perfect world, and large service centers set up passwords on customers' machines, also the aftermarket receives machines after service contracts with passwords set up.
                        So every service, even the smallest, should be able to remove passwords.
                        The fourth case is unarguable, but people lie and it is often difficult to distinguish between mistakes and deliberate action.
                        The first attempt to stop the problem has been made, and so far it has been successful.
                        You also have to consider that not all of the world is “first world” - and in many places people want and like to be cheated, just as much as they like to cheat - just such local folklore.​
                        • jotunn
                          • 637
                          #597
                          Originally posted by technics1210
                          Hello,
                          Thx.
                          Technics
                          Reset code for your machine:
                          MFP Serial Number A7PU021020615
                          Reset Code 9XADN-ZNKWB-3E5HQ-GTXK8-TYD58-6G8YD-ENJQG-EZTDX
                          Regards
                          • technics1210
                            • Oct 2020
                            • 16
                            #598
                            It's worked out :-)
                            Thank you very much for that.
                            Wishing you a nice day
                            • wgkingwy
                              • Jun 2023
                              • 23
                              #599
                              my c266 dont enter SMode
                              Please help,thank you!
                              • wgkingwy
                                • Jun 2023
                                • 23
                                #600
