Konica c224 e can't access service mode
  • jotunn
    • 637
    #436
    Originally posted by Bsytech
    Yes thats true thank you
    It didn't want you to agree with me, but rather to check everything again - letter by letter.
    But as far as I can see, I most likely won't be able to generate the reset code due to an invalid date in the machine.
    • Bsytech
      • Sep 2024
      • 19
      #437
      Hi, guys please need reset code for this machine c308. Best regards
      Printer serial number
      A7PY047004590
      Mac Address
      00:20:6B:40:68:B0
      CE Password Reset Request Code XKWXD-74ETT-53X64-XA7GU-BF30C-CG8YD-CHZOG-EYDDD
      Thank you for reaching out the error corrected
      Thank you am best regards
      • jotunn
        • 637
        #438
        A7PY047004590
        Mac Address
        00:20:6B:40:68:B0
        I'm still seeing an errors, so it looks like you haven't done what I asked. It's waste of my time.
        • Bsytech
          • Sep 2024
          • 19
          #439
          A7PY047004590
          Mac Address
          00:20:68:40:68:B0
          CE Password Reset Request Code XKWXD-74ETT-53X64-XA7GU-BF3QC-CG8YD-CMZQG-EYDDD
          Sorry please
          Thank you best regards
          • jotunn
            • 637
            #440
            A7PY047004590
            Mac Address
            00:20:68:40:68:B0
            Sorry please
            Better, however as I thought earlier, you've got wrong date set in the machine:
            Failed to verify the CE Password Reset Request Code.
            The entered CE Password Reset Request Code cannot be used due to the expiration. (MFP date in the code: 2013/01/01)
            So I can only guess the reset code, but with no warranty that it will work for your machine.
            Try this one:
            X2MCN-QAZN4-L7969-BT3PE-UKDKJ-WG8YD-CMZQG-EYDDJ
            • Bsytech
              • Sep 2024
              • 19
              #441
              Thank you I will try it and gives update on it. Best regards
              • ProfessorMatt
                • Oct 2024
                • 1
                #442
                Hey,
                We use 2 bizhubs c284e to teach print server management. Unfortunately, I think one of my student played a bit too much in the settings of one of them and now we have a C-D262 trouble code... and a non-standard CE password. Would it be possible to get a reset code so I can get in and fix the error?
                Serial #: A5C2011005518
                MAC address: 00:20:6B:8B:A1:6E
                CE password reset request code: AL7BJ-BC4QD-KVNY4-4HQCL-VCW28-6G8YD-ENBRG-AZDHR
                Thanks in advance to anyone who can help!
                • jotunn
                  • 637
                  #443
                  Originally posted by ProfessorMatt
                  Hey,
                  Reset code for your machine:
                  MFP Serial Number A5C2011005518
                  Reset Code 2WL4G-58BQU-2FQ4P-QCJZK-F9QA6-6G8YD-ENBRG-AZDJD
                  Regards
                  • hot_tracks
                    • Oct 2024
                    • 14
                    #444
                    Hello Jotunn,
                    Would be obliged if you could kindly provide a reset code for the machine below.
                    Printer Serial No: А5C4041115260
                    Request Code: 847ST-DKPVV-3G3FX-QJFJB-6LTFX-GG8YD-ANZQG-4ZDJX
                    MAC ID: 00:20:6B:AA:38:C7
                    Thank you.
                    • jotunn
                      • 637
                      #445
                      Originally posted by hot_tracks
                      Hello Jotunn,
                      Thank you.
                      Your machine has currently no serial number set - I'm sure, there was an empty space on your request screen in place of serial number.
                      Additionally machine has wrong date set:
                      The entered CE Password Reset Request Code cannot be used due to the expiration. (MFP date in the code: 2007/07/24)
                      So probably your machine lost all settings, including counters - intentionally or not.
                      Set current date and time if you can (probably not, because the admin password is also corrupted) - without this I won't be able to help you.
                      Regards
                      • hot_tracks
                        • Oct 2024
                        • 14
                        #446
                        Thank you for trying to help.
                        I forgot to mention that the battery on the board had gone weak /dead and when we had shut it down for routine mainenance the settings were corrupted. I have tried the NVRAM reset and it gets to the stage of the D390 error. It goes through the procedure of doing the recovery and the message to cycle power is displayed. Once that is done 4 sharkfins / towers come up and the amber light keeps blinking and stays that way.
                        I have left it like that for 24 hours to check but unfortunately no luck. When disconnected from main power and the reset tool is run again, after the D390 error comes up I can acess the menu (the machine has reverted back to the Japanese menu) where I can enter service mode to enter the password. The default password was not changed (9272 four times) but it looks like the admin password is corrupted as you have surmised.
                        • jotunn
                          • 637
                          #447
                          [...] where I can enter service mode to enter the password. The default password was not changed (9272 four times) but it looks like the admin password is corrupted as you have surmised.
                          So if you can enter service mode, you can set new admin password (even the same as default one) as well - [Stop] -> [0] -> [C] then [Administrator Password]
                          • IAN B.C.N.
                            • Oct 2024
                            • 6
                            #448
                            Printer Serial Number: A61E012001728
                            Mac Address: 00:20:68:92:E9:C1
                            CE Password Reset Request Code: 9CU4W-KZJF6-X988P-NQAM9-2B72K-6G8YD-ENBRG-AZDT7
                            Thank you for your help
                            • jotunn
                              • 637
                              #449
                              MFP Serial Number A61E012001728
                              Reset Code QF33M-QQHSV-GU4YB-MWRET-TEEPC-6G8YD-ENBRG-AZTBH
                              Regards
                              • hot_tracks
                                • Oct 2024
                                • 14
                                #450
                                Sorry for not being clear. I mean I can get up to the service mode login screen (where I have to enter the password). If I try to enter 9272 four times I get the message "Your authentication is currently invalid due to unauthorised access". If I enter [Stop] -> [0] -> [C] it brings up the CE Reset Screen but since serial number is not displayed and date is wrong a reset code cannot be generated by you.
