Konica c224 e can't access service mode
  • Synthohol
    Certified Konica Expert
    • 5824
    #421
    i was only warning you to be cautious.
    • Bsytech
      • Sep 2024
      • 19
      #422
      Okay thank you appreciate it
      • 黄圳发
        • Sep 2024
        • 10
        #423
        Dear jotunn
        jotunn
        Please help me with reset code for a bizhub B658E, There was an error in my certificate management.
        Thank you so much!
        SERIAL NUMBER: 479J013005740
        Repair the request code :8AKXN-59W5Z-JBTE6-8QPUC-KM4HS-2AAAA-BJ5KV
        Request code: AMKUZ-PNFQ3-JJ7Y6-6U6Y6-KBZDJ-PVW5U
        If it's convenient ,I have another question. How to register the i-Option function? It requires a code.
        • femaster
          • May 2011
          • 1504
          #424
          Originally posted by 黄圳发
          Dear jotunn
          jotunn
          Thank you so much!
          That issue is a little bit different since you can already access service mode. You will need to do what is in the following post:
          https://www.copytechnet.com/forum/te...303#post792303
          For the i-option function, you will need to pay for a license code from Konica Minolta. There is no way around that requirement.
          • MLDG_D
            • Oct 2024
            • 2
            #425
            jotunn
            Could I please get a reset code for the following:
            SN: A92F021035342
            Request code: 2ANWY-5ZEP8-QPNBN-HPHNM-LMTXM-CG8YD-ENBRG-AYTLF
            Thanks in advance!
            • jotunn
              • 617
              #426
              Originally posted by MLDG_D
              jotunn
              SN: A92F021035342
              Thanks in advance!
              You've missed MAC address of the machine.
              • MLDG_D
                • Oct 2024
                • 2
                #427
                mac is:
                00:20:6B:EC:CC:59
                • jotunn
                  • 617
                  #428
                  mac is:
                  00:20:6B:EC:CC:59
                  Reset code for your machine:
                  MFP Serial Number A92F021035342
                  Reset Code VER6R-GMSBE-YFE3Z-3GFAC-AK988-KG8YD-ENBRG-AYTN5
                  Regards
                  • BeardyDude
                    • May 2022
                    • 2
                    #429
                    Hiya, got a bizhub c224e at home (not profiting from this!) and realised the CE pass was non standard when trying to do a re-init to fix missing network settings from admin menu!
                    Serial: A5C4021183208
                    Mac: 00:20:6B:A9:853
                    4JMHL-FZ72F-HDBXM-5N79M-XQ7CF-SG8YD-ENBRG-AYTFZ
                    Can I get a reset code please?
                    I'd also love updated firmware, to fix SMB 1.0 limitation on scanning to NAS. Currently on A5C10YO-F000-GDJ-M1(00)
                    • jotunn
                      • 617
                      #430
                      MFP Serial Number A5C4021183208
                      Reset Code RNHJP-PRQZF-KC7UV-2AJ4E-5WYNS-CG8YD-ENBRG-AYTN3
                      Regards
                      • Bsytech
                        • Sep 2024
                        • 19
                        #431
                        Hi, guys please need reset code for this machine c308. Best regards
                        Printer serial number
                        A7PY047004590
                        Mac Address
                        00:20:68:40:68:80
                        CE Password Reset Request Code XKWXD-74ETT-53X64-XA7GU-BF30C-CGBYD-CHZOG-EYDDD
                        • jotunn
                          • 617
                          #432
                          A7PY047004590
                          Mac Address
                          00:20:68:40:68:80
                          Check your data again:
                          Failed to verify the CE Password Reset Request Code.
                          The entered CE Password Reset Request Code, MFP Serial Number or MAC Address is invalid.
                          • Bsytech
                            • Sep 2024
                            • 19
                            #433
                            A7PY047004590
                            Mac Address
                            00:20:68:40:68:B0
                            Thank you for reaching out the error is from Mac address have correct it.
                            Thank you am best regards
                            • jotunn
                              • 617
                              #434
                              A7PY047004590
                              Mac Address
                              00:20:68:40:68:B0
                              Not only, I can see another one - instead of CGBYD should probably be CG8YD
                              • Bsytech
                                • Sep 2024
                                • 19
                                #435
                                Yes thats true thank you
