Konica c224 e can't access service mode
  • jotunn
    • 618
    #286
    Re: Konica c224 e can't access service mode
    Originally posted by wgkingwy
    Unable to add image
    Upload image here -> Imgur: The magic of the Internet and post your link in the message.
    • Efcie
      • Jun 2022
      • 9
      #287
      Hi All,
      I have the same issue..
      SERIAL N0#: ACKN041000630
      MAC ADDR: 00:20:6B:FB:E7
      PASSWORD RESET REQUEST CODE: VKXQU-CRWQS-4DK8T-MZQ6T-FJPQU-SG8YD-CNZRG-8YDR5
      Your help in this will be much appreciated.
      Thank you
      • Synthohol
        Certified Konica Expert
        • 5849
        #288
        maybe throw jotunn some rep points for the assists huh?
        click the sheriffs badge under his avatar and add reputation.
        he did you a solid, please return the favor!!
        • jotunn
          • 618
          #289
          Originally posted by Efcie
          Hi All,
          Thank you
          Missing part of MAC Address and wrong date&time set in the machine.
          I will not be able to help unless you correct these problems.
          Regards
          • Efcie
            • Jun 2022
            • 9
            #290
            Regards
            Apologies,
            Correct one below:
            MAC ADDR: 00:20:6B:F8:FB:E7
            THANK YOU
            • imagicopy
              • Sep 2011
              • 1
              #291
              Hi Jotunn,
              I received a printer from one of my clients but I can't seem to get access to CE. Would you please unlock if it's possible? Thank you.
              BH C368
              Serial # A7PU018000002
              MAC # 00:20:6B:A1:92:8D
              REQUEST CODE: ZU8LA-6QC3Y-26CG8-893U5-ZVMMN-9G8YD-ENBQG-QZDJR
              Thank you in advance
              • jotunn
                • 618
                #292
                Originally posted by imagicopy
                Hi Jotunn,
                Reset code for your machine:
                MFP Serial Number A7PU018000002
                Reset Code W9TLU-K4CES-VWFFA-CG7NJ-9CNGB-KG8YD-ENBQG-QZDLP
                Regards
                • offli
                  • 2
                  #293
                  Hello jotun,
                  As announced, I have the following request:
                  Konica C227
                  Seri: A798021120115
                  Mac: 00:20:6B:AF:16:A7
                  Talep Kodu: 8KYA6 FZ6CZ DR64C BF6F3 MXD49 9G8YD ENBQG QZDLH
                  Thank you 🥰
                  • image_123
                    • Apr 2024
                    • 17
                    #294
                    Dear Jotunn
                    Please can you help me with reset code for a bizhub C360i, I don't remember the password to access the service mode.
                    MFP SERIAL NUMBER: AA2J041000915
                    MAC: 00:20:6B:6F:A1:16
                    Reset code: TWWMN-9G4XW-QUL9Z-P34CT-D743P-CG8YD-ENBQG-QZDLF
                    Thank you so much
                    • jotunn
                      • 618
                      #295
                      Originally posted by image_123
                      Dear Jotunn
                      Thank you so much
                      Your machine seems to have no serial number defined - it's just empty.
                      Reset Code K8GF9-XC3QN-KS8WC-LJZ3V-BSJSU-WG8YD-ENBQG-QZDNF
                      Regards
                      • TECNICOKM
                        • Jan 2021
                        • 4
                        #296
                        Dear Jotunn
                        Please can you help me with reset code for a bizhub C224e and , I don't remember the password to access the service mode.
                        MFP SERIAL NUMBER: A5C4011007937
                        MAC: 00:20:6B:8B:81:E6
                        Reset code: 9JRHP-XXPLS-E5VVS-FCJQZ-5JP2F-6G8YD-ENBQG-QZDLB
                        MFP SERIAL NUMBER: A5C4011008813
                        MAC: 00:20:6B:8B:BD:FA
                        Reset code: 4LMRH-BQ48T-677BJ-TS9BU-FLU3V-GG8YD-ENBQG-QZDL5
                        Thank you so much
                        • image_123
                          • Apr 2024
                          • 17
                          #297
                          Dear Jotunn
                          Reset code: 9BNX8-BY4YZ-UGBLU-F6FCG-PM96C-CG8YD-ENBQG-QZDN5
                          Thank you so much
                          • elmaligno
                            Expert technician KM
                            • Oct 2009
                            • 302
                            #298
                            I don't understand why there is so much fuss about "forgotten passwords" if there is a tool called reset tools that resets the factory password in 20 seconds.
                            Field technician since 1994
                            • jotunn
                              • 618
                              #299
                              Because reset tool is not intended to use in this way - for just resetting password - this is just side effect of other things done by reset tool.
                              Moreover, at least some of the problems with 'forgotten passwords' are due to misuse of the reset tool, which is difficult to admit here.
                              One, and only officially supported way to reset CE password is reset code.
                              • jotunn
                                • 618
                                #300
                                Dear Jotunn
                                Thank you so much
                                Again?
                                Reset Code VKYEJ-XKXHG-CVVYN-RMX6A-7A4FP-6G8YD-ENBQG-QZDNV
