Konica c224 e can't access service mode
  • Konik
    • Apr 2020
    • 16
    #196
    Re: Konica c224 e can't access service mode
    Thank you. Exactly.
    It was some time ago, I placed the copier in the corner because
    I didn't have time to solve this problem.
    This week I will dig it out and run it to generate a new request code.
    I didn't expect that the request code had an expiration date
    How long is it valid?
    • rrrohan
      • Sep 2011
      • 1977
      #197
      can you not just wind the clock and date back on the copier to a point in time where reset code was still valid?
      • jotunn
        • 618
        #198
        @rrrohan
        We are in the opposite situation - I can't rewind LMS servers date&time
        @Konik
        With properly set time and date in the machine request code should be valid for one week.
        So when you dig up your machine, just check date&time and prepare new request code.
        • rrrohan
          • Sep 2011
          • 1977
          #199
          oh i didnt realise it used LMS lol
          • Konik
            • Apr 2020
            • 16
            #200
            Hi
            My task is a bit difficult because I am currently outside my country.
            I talked to the service and they generated a current request code for me.
            They also checked the date, it's ok.
            At the same time, they made me aware that there are also 2 devices with an unknown CE Password on the lower floor of my warehouse
            If you are so kind, I will ask for help again in the future (2-3 weeks).
            Here is the current request code:
            Serial: A7R0027056006
            Mac: 00:20:6B:41:16:4B
            Request Code: HWU8L-PP9CW-YRVWB-4MFKK-RBAPF-9G8YD-ENBQG-EYTLL
            • jotunn
              • 618
              #201
              Originally posted by Konik
              Hi
              No problem at all.
              Below, reset code for your machine:
              MFP Serial Number A7R0027056006
              Reset Code KKGMN-C6DUF-9A6Q6-B6393-852BC-9G8YD-ENBQG-EYTPR
              • Konik
                • Apr 2020
                • 16
                #202
                Thanks very, very much!!!
                Tomorrow the service technicians will try to do it.
                • Konik
                  • Apr 2020
                  • 16
                  #203
                  Hello.
                  As announced, I have the following request:
                  Serial: A7R0027048047
                  Mac: 00:20:6B:40:95:96
                  Request Code: XHBGV-UNHEE-ZKXGG-HUJFL-YKSFW-9G8YD-ENBQG-EYTLL
                  Thank you very much
                  • jotunn
                    • 618
                    #204
                    Reset code for your machine:
                    MFP Serial Number A7R0027048047
                    Reset Code AB6KR-UBLEJ-MVZP4-MCQCH-X2EZS-9G8YD-ENBQG-EYTRR
                    Regards
                    • Konik
                      • Apr 2020
                      • 16
                      #205
                      And one last device if possible:
                      Serial: A5C4021121533
                      Mac: 00:20:6B:8D:7B:F3
                      Request Code: SPNX6-9RQW7-6VK94-EJZ4B-UPAPF-GG8YD-ENBQG-EYTLD
                      Regards
                      • jotunn
                        • 618
                        #206
                        MFP Serial Number A5C4021121533
                        Reset Code M27Z2-FTKKS-AMZWK-VN33X-9JCNG-GG8YD-ENBQG-EYTTX
                        Regards
                        • digitechf7
                          • Jan 2024
                          • 2
                          #207
                          Hello.
                          Serial: A7AH047001872
                          Mac: 00:20:6B:3A:AF:CF
                          Request Code: JWMV6-V6H3G-WGUHN-ZWZEP-7F6JP-KG8YD-ENBQG-EZDFR
                          Thank you very much
                          • jotunn
                            • 618
                            #208
                            Originally posted by digitechf7
                            Hello.
                            Thank you very much
                            MFP Serial Number A7AH047001872
                            Reset Code 3Y78E-RHNRL-6KJUJ-JCP9W-ZUW83-6G8YD-ENBQG-EZDF5
                            Regards
                            • vikvvb
                              • Jan 2024
                              • 3
                              #209
                              AA6V041001894
                              HADCT-VZA4G-LNQ3F-SVYWT-GYBQ7-WG8YD-EMZQG-MYDLN
                              [ATTACH=CONFIG]57129[/ATTACH]
                              Hello Jotun, i also have a trouble with CE psw. I will be very grateful if you can help me also with my printer.
                              Printer Serial Number
                              ACVD021007862
                              MAC Address
                              00:20: 6B: FB: 94: A1
                              CE Password Reset Request Code HMSE2-662J7-0N5LY-B752N-P24EL-WG8YD-ENBQG- EZDTH
                              • jotunn
                                • 618
                                #210
                                ACVD021007862
                                MAC Address
                                Check again the data you sent, surely there should not be the letter O or the number 0 in the request code.
