Konica c224 e can't access service mode
  • jotunn
    • 635
    #256
    Re: Konica c224 e can't access service mode
    Originally posted by Adruk21
    MFP Serial Number A7R0027004681
    Mac-adresse 00:20:6B:B6:44:B8
    Reset Requet Code HRFSW-2ESUH-EBF2L-LBGH2-L87QA-CG8YD-ENBQG-MZDT7
    Try this one:
    Reset Code ZL5NT-FSPKJ-T2PMF-GDSRE-VD8X7-6G8YD-ENBQG-QYDLH
    or
    Reset Code ZL5NT-FSPKJ-T2PMF-GDSRE-VD8X7-6G8YD-ENBQG-MZDLH
    • Adruk21
      • Apr 2024
      • 6
      #257
      Sorry, but the printer password has changed and that code does not work. can you help again.
      • Adruk21
        • Apr 2024
        • 6
        #258
        New
        Reset Requet Code AJUE4-8Z44F-HNBNQ-VE8EN-A544R-WG8YD-ENBQG-QYDLV
        • jotunn
          • 635
          #259
          New
          New reset code:
          Reset Code Z9YLB-DCGMX-FGLTG-PXG24-CAYYY-KG8YD-ENBQG-QYDLP
          Regards
          • Synthohol
            Certified Konica Expert
            • 5894
            #260
            i bumped your rep up man, everyone you assist owes you at least that.
            • Adruk21
              • Apr 2024
              • 6
              #261
              Thank you very much. I was already thinking about disassembling the printer for parts, but you saved it.
              • mkdirs
                • Oct 2014
                • 177
                #262
                Can you help please
                Serial: A789081002714
                MAC: 00:20:6B:B8:F5:E4
                CE REQUEST: H9T7S-F4ZD3-B6TWM-5QQD4-V9ERS-GG8YD-ENBQG-QYDPV
                THANKS
                Xerotk.com
                xerox copier technician
                • jotunn
                  • 635
                  #263
                  Originally posted by mkdirs
                  Can you help please
                  THANKS
                  Reset code for your machine:
                  MFP Serial Number A789081002714
                  Reset Code 3G645-JMMD4-L5HKJ-2G8PC-RZJBB-SG8YD-ENBQG-QYDRZ
                  Regards
                  • Dougtech
                    • Apr 2011
                    • 113
                    #264
                    Originally posted by jotunn
                    Unfortunately, both codes are expired - probably few hours earlier it would work.
                    Please prepare new codes.
                    The entered CE Password Reset Request Code cannot be used due to the expiration. (MFP date in the code: 2024/03/29)
                    Regards
                    Thanks. just got these today.
                    C368 #1
                    Serial# A7PU012000656
                    MAC 00:20:6B:A1:91:1C
                    RESET REQUEST CODE WUJZ8-T5DH9-Y327Q-84VHV-6LJJF-KG8YD-ENBQG-QYDRH
                    C368 #2
                    Serial# A7PU012000675
                    MAC 00:20:6B:A1:91:60
                    RESET REQUEST CODE DZZSE-89MQM-8UXVW-F8C8Z-Z7DQ7-CG8YD-ENBGQ-QYDRF
                    Thank you
                    • jotunn
                      • 635
                      #265
                      C368 #1
                      C368 #2
                      Thank you
                      Your reset codes:
                      MFP Serial Number A7PU012000656
                      Reset Code GEHP4-QG2R9-TKYH5-V9A8A-WVLZX-WG8YD-ENBQG-QYDTP
                      MFP Serial Number A7PU012000675
                      Reset Code 8Y3A3-YDVZB-SYKEW-LWE2V-RVBMD-6G8YD-ENBQG-QYDT5
                      Regards
                      • Synthohol
                        • 5894
                        #266
                        someone throw jotunn some rep points for the assists huh?
                        click the sheriffs badge under his avatar and add reputation.
                        he did you a solid, please return the favor!!
                        • digitechf7
                          • Jan 2024
                          • 2
                          #267
                          Serial: A7AH041000731
                          MAC: 00:20:6B:9C:69:44
                          CẢM ƠN
                          • jotunn
                            • 635
                            #268
                            CẢM ƠN
                            Your reset code:
                            MFP Serial Number A7AH041000731
                            Reset Code NKMTK-2FGKQ-SMXFY-CGC9A-LP2ET-6G8YD-ENBQG-QYTB7
                            Regards
                            • Hoov
                              • Mar 2024
                              • 13
                              #269
                              Just ran across this thread and realized it has been going on for over 2 years. Thanks Jotunn for helping.
                              If you could help me as well I would be appreciative. I have to 650i's both with changed CE passwords.
                              Serial Number is AA7N011001940
                              MAC Address is 00:20:6B:F6:42:49
                              Reset request code is HN2QK-HU47U-XVSNA-HE9G8-WKSAM-SG8YD-ENBQG-QYTDD
                              Serial Number is AA7N011001889
                              MAC Address is 00:20:6B:F6:43:ED
                              Reset request code is JLF93-KSXCT-FJCVK-XHERN-F9KQZ2-WG8YD-ENBQG-QYTDZ
                              Thanks Again
                              Last edited by Hoov; 04-11-2024, 09:41 PM. Reason: Add information I foolishly forgot
                              • jotunn
                                • 635
                                #270
                                If you could help me as well [...]
                                Thanks Again
                                I wish, however you've got lacking MAC Adresses, and the fifth group of the second request code, have got redundant number/letter...
                                Regards
