Konica c224 e can't access service mode
  • jotunn
    • 607
    #331
    Originally posted by image_123
    Dear Jotunn
    Please can you help me with reset code for a bizhub 287, I don't remember the password to access the service mode.
    MFP serial number: A7AH001001852
    MAC:00:20:6B:9D:61B
    Request code: FHK3J-6CYES-QKUFU-MQ2JN-ZWQ86-9G8YD-EMRRG-8ZDF5
    Thank you so much
    Wrong date set in the machine.
    The entered CE Password Reset Request Code cannot be used due to the expiration. (MFP date in the code: 2022/12/22)
    However you can try this one:
    SVD8A-X5K94-H78GA-CP2M2-NKLDK-2G8YD-EMRRG-8ZDJP
    If it doesn't work, set proper date and time in your machine and send me new request code.
    Regards
    • RTK
      • Jul 2024
      • 2
      #332
      Hi Jotunn,
      Today I got a KM C364e which was under service contract at the last owner. For that there is activated remote care I now want to disable but I can not get into service mode with standard CE pw.
      Maybe you can help me to reset it?
      SN: A5C1021027585
      MAC: 00-20-6B-97-47-DF
      pw reset request code: Z2MUC-Z2TBC-BWALM-D7TPS-6N8VQ-6G8YD-ENBQG-4ZTBZ
      Thank you in advance!
      Best regards
      Kevin
      • jotunn
        • 607
        #333
        Originally posted by RTK
        Hi Jotunn,
        Best regards
        Kevin
        Reset code for your machine:
        MFP Serial Number A5C1021027585
        Reset Code VN3LZ-RC3BT-HUSHJ-8GYEL-TCRJ3-6G8YD-ENBQG-4ZTDF
        Regards
        • RTK
          • Jul 2024
          • 2
          #334
          Hi,
          it works.
          Thank you so much!
          Best regards
          Kevin
          • Compvar58
            Senior Field Technician
            • Jun 2013
            • 11
            #335
            Jotunn if you have time to work through this for me, I also need your help with a CE password reset.
            • w4274637
              • Aug 2024
              • 8
              #336
              Regards
              We have a printer model BizhubC266I, and the service password may have been maliciously modified, preventing us from logging into CE mode for maintenance. A friend suggested I seek help on a forum, and I've also heard that the reset code can be calculated using the serial number, MAC address, and CE password reset code.
              Our printer serial number is: AAJ1081000628,
              MAC address is: 00:20:6B:EF:48:EC,
              CE password reset request code is: MWP8H-9HH3U-6DEMM-VYRKF-GMWSZ-GG8YD-ENJRG-AZDR3
              Hope you can help me
              Thank you!
              • jotunn
                • 607
                #337
                Thank you!
                MFP Serial Number AAJ1081000628
                Reset Code ZGPV3-6FHQT-BYKXJ-VUKFZ-GL6PG-6G8YD-ENBQH-AYDNN
                Regards
                • w4274637
                  • Aug 2024
                  • 8
                  #338
                  Regards
                  Woah! I didn't expect to hear from you so soon. Thank you so much
                  • w4274637
                    • Aug 2024
                    • 8
                    #339
                    Regards
                    I just released the code of the previous two days. I had no idea that the code would change. I'm truly sorry.
                    The current serial number is: AAJ1081000628.
                    The MAC address is: 00:20:6B:EF:48:EC.
                    The CE password reset request code is: STBYL-VV4HN-ER7H6-8PHFJ-M2FTB-KG8YD-ENJRG-EYDRL.
                    Please calculate it for me once again. I would be extremely grateful!
                    • jotunn
                      • 607
                      #340
                      It doesn't matter - codes are valid for a week. Request code is time-based so constantly changes.
                      Previous reset code should work, however below is the new one.
                      Reset Code A2UQH-YSCLQ-T22CF-3AY46-4TVQE-6G8YD-ENBQH-AYDN3
                      Regards
                      • w4274637
                        • Aug 2024
                        • 8
                        #341
                        Regards
                        Thank you very much indeed
                        • alberto
                          • Oct 2011
                          • 10
                          #342
                          HelLo Jotunn
                          Can you please help with the following
                          Printer Serial Number A92F321001715
                          MAC Address 00:20:6B:ECA:C4
                          Request Code 4PRUJ-Q5T8L-SWEA8-5BVHX-ZHCL2-2G8YD-ENBQH-AYDNB
                          Thank you very much for your time
                          • jotunn
                            • 607
                            #343
                            Originally posted by alberto
                            HelLo Jotunn
                            MFP Serial Number A92F321001715
                            Reset Code SY4XU-HJRAX-RH9SP-4XJHR-CKU3F-SG8YD-ENBQH-AYDR5
                            Regards
                            • alberto
                              • Oct 2011
                              • 10
                              #344
                              Worked like a charm!
                              Very grateful to you Jotunn
                              Thanks very much
                              • dangmenghui
                                • Aug 2024
                                • 2
                                #345
                                Dear Jotunn
                                Please help me with reset code for a bizhub C266, I don't remember the password to access the service mode.
                                Serial number: A90G081004390
                                MAC:00:20:6B:BE:0D:49
                                Request code: BSUPQ-RNYTW-77MUM-7NJ6X-N8PL9-WG8YD-ENBQH-AYTHP
                                Thank you so much!
