Konica c224 e can't access service mode
  • doinbox
    • Jan 2013
    • 112
    #241
    Re: Konica c224 e can't access service mode
    Hi, I've been advised to leave a comment in here with help resetting CE password on C224e
    Serial Number - A5C4021186145
    MAC Address - 00:20:6B:A9:A7;D1
    CE Password Reset Request code - 6N67D-BCUQE-M7J8Z-RRA4J-69NG2-GG8YD-ENBQG-MZDPF
    Many thanks for any help with this.
    Had to put a ; before the D in Mac address because if I put : before the D it puts an emote
    Last edited by doinbox; 03-27-2024, 04:07 PM. Reason: Put C224w instead of C224e, Mac Address mistake corrected
    • femaster
      • May 2011
      • 1514
      #242
      These should get you in:
      MFP Serial Number A5C4021186145
      Reset Code BN8YJ-EECMM-EDU5D-JFL4J-ACGEE-KG8YD-ENBQG-MZDRP
      • doinbox
        • Jan 2013
        • 112
        #243
        You're a legend mate. Thankyou so much. Will be going down tomorrow so will post to let you know it worked. Cheers.
        • wjurls
          • Feb 2017
          • 498
          #244
          Does this method work on Production Machines? Particularly a C14000? I can't seem get the reset screen on production machines using the Stop ->Clear method from the input password screen. Mind you I am trying this on a Pro 1100 because the C14000 is 230 miles away from me.
          Thanks in advance.
          Lee
          • jotunn
            • 618
            #245
            No, it doesn't work, as I said here -> CE Password Recovery
            As far, as I know, the only official way for production machines is NVRAM replacement.
            So I can't help you in this case.
            • wjurls
              • Feb 2017
              • 498
              #246
              That's what I was afraid of. Thanks for your time anyway.
              • Guest
                #247
                need help resetting my bizhub c 6000 ce password
                serial no is A1DV021002489
                Thank you in advance
                • Synthohol
                  Certified Konica Expert
                  • 5849
                  #248
                  ^^^^in case you missed it^^^^
                  • doinbox
                    • Jan 2013
                    • 112
                    #249
                    Just wanted to say thanks again for this. Customer up and running again. Have a great Easter.
                    • Adruk21
                      • Apr 2024
                      • 6
                      #250
                      Hello.
                      You could please help us with locked c258 machine, we would be grateful?
                      Serial Number A7R0027004681
                      Reset Requet Code HRFSW-2ESUH-EBF2L-LBGH2-L87QA-CG8YD-ENBQG-MZDT7
                      • Dougtech
                        • Apr 2011
                        • 113
                        #251
                        Hi,
                        Just wanted to see if you would help me with 2 Bizhub C368 I received recently. Tried all usual CE passwords but they don't work.
                        If you can
                        C368 #1
                        serial # A7PU012000675
                        MAC 00:20:6B:A1:91:60
                        Reset request code P787J-TNPKK-XFD6A-FB7F3-32UFJ-WG8YD-ENBOG-MZDTT
                        c368 #2
                        serial # A7PU012000656
                        MAC 00:20:6B:A1:91:1C
                        Reset request code 97U8G-YGT25-2M7X3-ZEUCD-X7548-GG8YD-ENBQG-MZDTP
                        Any help greatly appreciated
                        • jotunn
                          • 618
                          #252
                          Originally posted by Dougtech
                          Hi,
                          If you can
                          C368 #1
                          c368 #2
                          Unfortunately, both codes are expired - probably few hours earlier it would work.
                          Please prepare new codes.
                          The entered CE Password Reset Request Code cannot be used due to the expiration. (MFP date in the code: 2024/03/29)
                          Regards
                          • Adruk21
                            • Apr 2024
                            • 6
                            #253
                            Originally posted by Adruk21
                            Hello.
                            can you help me with my problem? Regards.
                            • jotunn
                              • 618
                              #254
                              I need a complete set of data that the machine displayed - serial number, MAC address and request code.
                              • Adruk21
                                • Apr 2024
                                • 6
                                #255
                                MFP Serial Number A7R0027004681
                                Mac-adresse 00:20:6B:B6:44:B8
