Konica c224 e can't access service mode
  • jotunn
    • 640
    #91
    Re: Konica c224 e can't access service mode
    Once again, your code:
    MFP Serial Number A5C1021018523
    Reset Code ZE4JC-8DM67-LV593-SJYXZ-6FCRD-CG8YD-EMZQG-4ZDP5
    Press [Reset Code Input] on screen you have posted, enter the above reset code and confirm with [End].
    After confirmation, the machine should enter directly into ce mode, and passwors should be reset to default.
    However your machine is in failure state (C-4802) so I can't predict exact behavior.
    • furius
      • Jan 2018
      • 34
      #92
      Originally posted by jotunn
      crea una foto chiara e leggibile della schermata del codice di ripristino della password (con numero di serie e indirizzo mac). Forse posso aiutarti, se la macchina ha la data/ora corretta impostata.
      ciao mi avevi gia risposto pero ho notato che il codice era cambiato :-(
      [ATTACH=CONFIG]59089[/ATTACH]
      • jotunn
        • 640
        #93
        • jotunn
          • 640
          #94
          It doesn't matter, the code includes the current time, so it will be different every time.
          This is the last code, I don't have spare life to waste more time for you.
          Reset Code BMLQB-AH8GD-KF3NV-BKXY6-K5FM5-2G8YD-EMZQG-4ZDP3
          • furius
            • Jan 2018
            • 34
            #95
            • Synthohol
              Certified Konica Expert
              • 5910
              #96
              excuse me but are you out of your mind?
              how utterly ungrateful for his time and service to you for NOTHING in return.
              you have a lot of nerve talking like that to him, Jotunn has done nothing but try to help you.
              you can pound salt now, nobody rips into one of our members that goes above and beyond.
              next time call Konicaminolta and pay hundreds of dollars for a service call to get you access back to service mode.
              you are a real piece of work.
              for those who didnt translate, heres what he said to Jotunn..
              okay! I apologize in time if I bothered you. the code you sent me doesn't work, I think because more time passes. I want to understand for what fucking reason you are with me and you answer me like a fuck. you are really rude and ill-mannered. I may have confused the public channel or private messages, but this is not the right reason to treat me like an imbecile, you are uncivilized. Just for the record I'm not Italian I'm Bulgarian.
              • furius
                • Jan 2018
                • 34
                #97
                • jotunn
                  • 640
                  #98
                  First of all, there is no possibility to remove messages here (only moderator can, but usually he's out there).
                  Yes I wrote the text about annoying Italians, however more as a joke, and _after_ the second reset code - because after two days of silence (priv with the first reset code) in 10 minutes you have wrote 4 messages in total, both in this topic and as a private messages (all of them in italian, even if we are all using english here).
                  None of those messages didn't gave me clear information about non-working code, instead I got additional photos of request codes, written request codes (same as on photos).
                  Sorry that you felt offended by a joke about Italians, being a Bulgarian...
                  • tayfuner58
                    • Aug 2023
                    • 5
                    #99
                    Hi Jotunn, saw you've helped a lot of people, thanks for that you're amazing. I hope you can help me too, I have 2 bizhub c360i with which I have the same problem. I'll write down the serial numbers for you in the hope that you can do that too and thank you in advance.
                    Printer Serial Number: AA2J021006048
                    MAC address: 00:20:68:43:A6:66
                    CE Password Reset Request code: CESHS-ML8A9-UYRU-HXTEG-XFLXZ-2GBYD - ENZOH-AYTDF
                    Printer Serial Number: AA2J021003844
                    MAC address: 00:20:68:43:4:61
                    Password Reset Request Code: 44X9T-CM3LM-LD4BP-TOLT6-2GDZH-GG8YD-EMZOH-AYID5
                    • tayfuner58
                      • Aug 2023
                      • 5
                      #100
                      Apparently people don't understand jokes here..
                      • jotunn
                        • 640
                        #101
                        [QUOTE=tayfuner58;2444538]
                        You've got missing letter in 3rd sequence of the first request code, and missing number in MAC Address of the second code.
                        Check date and time again - sequences ENZOH/EMZOH looks bit strange.
                        You'd better post photos
                        • tayfuner58
                          • Aug 2023
                          • 5
                          #102
                          [QUOTE=jotunn;2444552]
                          copying was never my forte 😅
                          here again as a picture
                          • jotunn
                            • 640
                            #103
                            Your codes:
                            MFP Serial Number AA2J021003844
                            Reset Code RX6MX-5LSGP-RK4CP-7CNNM-5F3CE-6G8YD-EMZQH-AYTJL
                            MFP Serial Number AA2J021006048
                            Reset Code 3XY4T-94BY7-S9DJP-SJL8Z-PYZLC-2G8YD-EMZQH-AYTJP
                            • tayfuner58
                              • Aug 2023
                              • 5
                              #104
                              Your codes:
                              you are a genius and my hero thank you a thousand times 😀
                              • cla65
                                • Jul 2023
                                • 17
                                #105
                                I also have the same problem with a bizhub 287,
                                ce and admin password changed, date is correct, time is forward by five minutes but i can't correct it.
                                is it possible to get some help?
                                Thank you
