Konica c224 e can't access service mode
  • JoSer
    • Oct 2023
    • 3
    #136
    Re: Konica c224 e can't access service mode
    I would also kindly request a CE reset code. The Request Code is:
    Serial: A798021109899
    MAC: 00:20:6B:AE:E4:CF
    Code: D32FX-2F9QQ-6MNUZ-QDS4M-UV6S8-KG8YD-EMZRG-AZDLL
    Thank you!
    • jotunn
      • 618
      #137
      Thank you!
      Your reset code:
      MFP Serial Number A798021109899
      Reset Code XF7WY-TKS3C-LRJAD-DT28M-MKNHA-KG8YD-EMZRG-AZDLB
      Regards
      • JoSer
        • Oct 2023
        • 3
        #138
        Originally posted by jotunn
        Your reset code:
        Regards
        Thank you very much! That worked. But unfortunately I switched back from the CE menu and there is still a password set. I thought this code will delete the current password. Is there a way to remove the CE password completely from within the CE menu?
        I also got a new code now and cannot enter again:
        4HZBW-N65C8-K5WRJ-XZWLZ-JEKJS-CG8YD-EMZRG-AZDL3
        • Bruno2001
          • Oct 2023
          • 5
          #139
          I Need your help these are Just the credentials:
          Serial Number:A5YN02700057
          MAC: 00:20:6B:92:38:34
          CE:E6F33-SYW7Z-MEBHR-UDG2U-7C8ZU-GG8YD-EMZRG-AYTTX
          • jotunn
            • 618
            #140
            The code removes the currently set password and restores the default one (and as a tech, you should know the default password).
            It is not possible to remove the password completely - you can only disable CE Authentication in Enhanced Security mode, then the machine will not ask for password anymore.
            • jotunn
              • 618
              #141
              Wrong serial number - too short, should be 13 characters long.
              Ok, I nailed it.
              You missed one "0", so the proper serial number seems to be A5YN027000057
              However your code is expired, I need the fresh one...
              Failed to verify the CE Password Reset Request Code.
              The entered CE Password Reset Request Code cannot be used due to the expiration. (MFP date in the code: 2023/10/19)
              • femaster
                • May 2011
                • 1514
                #142
                The reset code resets the password back to the factory default. Yes, there is a way to set the machine up to not request a password, but it does not completely eliminate it. The password would still be required under certain circumstances like entering from the trouble reset screen.
                • tulintron
                  • Jul 2014
                  • 668
                  #143
                  Have you tried Clear All Data?
                  • JoSer
                    • Oct 2023
                    • 3
                    #144
                    Ah! I forgot to check with the default password. The default password is working in CE menu now. Thank you very much!!
                    • Bruno2001
                      • Oct 2023
                      • 5
                      #145
                      Ok, I nailed it.
                      How do I generate a new code?
                      • jotunn
                        • 618
                        #146
                        The same way, as the first one - on the password screen press Stop -> C
                        This procedure generates fresh code (with actual date and time) each time.
                        Check that the machine has the correct date and time set, perhaps your machine had the wrong date set.
                        • Bruno2001
                          • Oct 2023
                          • 5
                          #147
                          Ok so the news codes are : SN:A5YN027000057
                          MAC:00:20:6B:92:38:34
                          CE:SFX5K-B7CJR-2Z2R8-E8R53-7FAA6-GG8YD-EMZRG-AZTBL
                          • jotunn
                            • 618
                            #148
                            Your reset code:
                            MFP Serial Number A5YN027000057
                            Reset Code RL2M7-N4JRZ-S6FB6-9ZJ38-XQRV5-CG8YD-EMZRG-AZTB5
                            • Bruno2001
                              • Oct 2023
                              • 5
                              #149
                              Serial number a5yn027000057
                              mac 00:20:6b:92:38:34
                              reset request code 9b99a-lbk2g-8fnj7-m4d9t-xdagp-9g8yd-emzrg-aztbt
                              • AJF272645
                                • Oct 2023
                                • 2
                                #150
                                Hi jotunn,
                                I purchased a machine secondhand, are you please able to supply me with reset code for my C364e Locked out of CE Password and Konica has been no help to unlock it for me.
                                MFP Serial Number: A5C1041009924
                                MAC Address: 00:20:6B:8E:C5:C6
                                Reset Code: TFWGZ-B4G2D-ARVEK-YGVHV-8FAH6-GG8YD-EMZRG-AZTBP
                                Any help will be greatly appreciated, I feel like throwing this thing down the stairs!!!
