Konica c224 e can't access service mode
Re: Konica c224 e can't access service mode
MFP Serial Number ACVD021007862
Reset Code JAPWY-YW54Z-4VCVH-6Q6AD-B6L2A-WG8YD-ENBQG-EZDTN
RegardsComment
@dacam20590
You have run out of available space in your mailbox, you need to delete at least some of the messages. Currently, no message can be sent to you.
MFP Serial Number AAJ1041000523
Reset Code LRC8V-PJVNV-NTD6H-BJ8ET-DNQSV-6G8YD-ENBQG-EZTDBComment
A previous tech must have changed the service password. I have tried 9272 4 times and twice, 12345678 all that were suggested on the internet and then I'm allow me into the service mode. Is there any way to bypass the password or reset it. I have a c- f a14 code and need to get into the service mode to take care of it but I can't get past the password. Thanks
in service mode 2 you can put a new password
in service mode 2 you can put a new passwordComment
that post was from 2 years ago bud.
and how do you get into service 2 when it didnt allow them to login at all?We know a thing or two because we've seen a thing or two.
The medication helps though...Comment
@jotunn
Hi Jotunn,
I have a C250i which I have just replaced the CPU card and Storage board because they had failed.
I have done a storage board controller firmware update and normal firmware update and machine has been initialised, so the serial number is now blank.
I cannot log into service mode to enter the serial number because the 9272(x4) does not work.
Are you able to see if you can get a reset code if the serial number is blank? It still gives me a request code.
MFP Serial Number (BLANK)
MAC Address: 00:50:AA:44:2B:CB
CE Password Reset Request Code: 8QFW8-QGJ5U-KBZFF-SV8TP-TP7KT-KG8YD-ENBQ6-8YTJ7
Actual machine serial number: AA2M041008642
Thank you.Last edited by Lync; 02-14-2024, 06:35 AM.Comment
Thank you.
I still need the MAC address of the machine, I'm sure it was displayed on the reset screen.
Make sure, by the way, that you rewrite the request code without errors - there is probably an error in the one you wrote (ENBQ6 instead of ENBQG).Comment
@jotunn
I have exactly the same problem as Lync, if you can solve his problem please help me also.
Printer Serial Number (BLANK)
MAC Address: 00:20:6B:FC:FD:56
CE Password Reset Request Code: 8WCZG-VZKFF-H55EF-LU46X-HRXVQ-6G8YD-ENBQG-8YTJD
Machine serial number from label: ACVD321000796
You have tried to help me before but now Admin have fixed the problem with the inbox so I can receive messages again.Comment
There is no guarantee that it will work, but I can try.
Hi Jotunn
CE Password Reset Request Code: 8QFW8-QGJ5U-KBZFF-SV8TP-TP7KT-KG8YD-ENBQG-8YTJ7
The 6 was supposed to be a G. Thank you,
Lync.Comment
Reset Code 3BRAP-VEV86-PLN6Q-CTS45-CDP6U-GG8YD-ENBQG-8YTL5Comment
@jotunn
Reset Code GD3XH-QNDLS-46JSW-JFLFJ-J7557-SG8YD-ENBQG-8YTL5Comment
Re: Konica c364 e can't access service mode
Hello Jotunn,
I have a problem with the CE password for Biz C364e.
I'd be grateful if you can help me.
Serial: A5C1041016004
Mac: 00:20:6B:99:7A:1B
Request Code: FAQHW-DN7CJ-RY79P-F3PPH-ZQMTL-SG8YD-ENBQ6-8YTR5
Thank you in advance.Attached FilesComment
