Konica c224 e can't access service mode
  • vikvvb
    • Jan 2024
    • 3
    #211
    Re: Konica c224 e can't access service mode
    Originally posted by jotunn
    Check again the data you sent, surely there should not be the letter O or the number 0 in the request code.
    you are right, my bad, here is the correct code: WM5E2-662J7-QN5LY-B752N-P24EL-WG8YD-ENBQG-EZDTH
    • jotunn
      • 618
      #212
      Now the code is correct, so your reset code below:
      MFP Serial Number ACVD021007862
      Reset Code JAPWY-YW54Z-4VCVH-6Q6AD-B6L2A-WG8YD-ENBQG-EZDTN
      Regards
      • vikvvb
        • Jan 2024
        • 3
        #213
        Regards
        worked. great. Thank you so much
        • jotunn
          • 618
          #214
          @dacam20590
          You have run out of available space in your mailbox, you need to delete at least some of the messages. Currently, no message can be sent to you.
          MFP Serial Number AAJ1041000523
          Reset Code LRC8V-PJVNV-NTD6H-BJ8ET-DNQSV-6G8YD-ENBQG-EZTDB
          • augustoram260187
            • Jan 2024
            • 2
            #215
            Originally posted by DOE
            A previous tech must have changed the service password. I have tried 9272 4 times and twice, 12345678 all that were suggested on the internet and then I'm allow me into the service mode. Is there any way to bypass the password or reset it. I have a c- f a14 code and need to get into the service mode to take care of it but I can't get past the password. Thanks
            in service mode 2 you can put a new password
            • Synthohol
              Certified Konica Expert
              • Mar 2016
              • 5850
              #216
              that post was from 2 years ago bud.
              and how do you get into service 2 when it didnt allow them to login at all?
              • Lync
                • Feb 2016
                • 47
                #217
                @jotunn
                Hi Jotunn,
                I have a C250i which I have just replaced the CPU card and Storage board because they had failed.
                I have done a storage board controller firmware update and normal firmware update and machine has been initialised, so the serial number is now blank.
                I cannot log into service mode to enter the serial number because the 9272(x4) does not work.
                Are you able to see if you can get a reset code if the serial number is blank? It still gives me a request code.
                MFP Serial Number (BLANK)
                MAC Address: 00:50:AA:44:2B:CB
                CE Password Reset Request Code: 8QFW8-QGJ5U-KBZFF-SV8TP-TP7KT-KG8YD-ENBQ6-8YTJ7
                Actual machine serial number: AA2M041008642
                Thank you.
                • jotunn
                  • 618
                  #218
                  Thank you.
                  There is no guarantee that it will work, but I can try.
                  I still need the MAC address of the machine, I'm sure it was displayed on the reset screen.
                  Make sure, by the way, that you rewrite the request code without errors - there is probably an error in the one you wrote (ENBQ6 instead of ENBQG).
                  • B0265
                    • Jan 2007
                    • 718
                    #219
                    @jotunn
                    I have exactly the same problem as Lync, if you can solve his problem please help me also.
                    Printer Serial Number (BLANK)
                    MAC Address: 00:20:6B:FC:FD:56
                    CE Password Reset Request Code: 8WCZG-VZKFF-H55EF-LU46X-HRXVQ-6G8YD-ENBQG-8YTJD
                    Machine serial number from label: ACVD321000796
                    You have tried to help me before but now Admin have fixed the problem with the inbox so I can receive messages again.
                    • Lync
                      • Feb 2016
                      • 47
                      #220
                      Hi Jotunn
                      CE Password Reset Request Code: 8QFW8-QGJ5U-KBZFF-SV8TP-TP7KT-KG8YD-ENBQG-8YTJ7
                      The 6 was supposed to be a G. Thank you,
                      Lync.
                      • jotunn
                        • 618
                        #221
                        Hi Jotunn
                        Lync.
                        Try this:
                        Reset Code 3BRAP-VEV86-PLN6Q-CTS45-CDP6U-GG8YD-ENBQG-8YTL5
                        • jotunn
                          • 618
                          #222
                          Originally posted by B0265
                          @jotunn
                          Reset Code GD3XH-QNDLS-46JSW-JFLFJ-J7557-SG8YD-ENBQG-8YTL5
                          • Lync
                            • Feb 2016
                            • 47
                            #223
                            Try this:
                            Thank you Jotunn,
                            It worked. Did you put the serial number in or leave it blank?
                            Lync
                            • jotunn
                              • 618
                              #224
                              Thank you Jotunn,
                              Lync
                              Blank - machine in this state has no serial number defined.
                              • raveendrala
                                • Oct 2016
                                • 80
                                #225
                                Re: Konica c364 e can't access service mode
                                Hello Jotunn,
                                I have a problem with the CE password for Biz C364e.
                                I'd be grateful if you can help me.
                                Serial: A5C1041016004
                                Mac: 00:20:6B:99:7A:1B
                                Request Code: FAQHW-DN7CJ-RY79P-F3PPH-ZQMTL-SG8YD-ENBQ6-8YTR5
                                Thank you in advance.
