Konica c224 e can't access service mode
+ More Options
Posts
  • friendy82
    • May 2016
    • 1
    #76
    Re: Konica c224 e can't access service mode
    Hi. Having same issue.
    A797021100569
    00:20:6B:AE:EA:9D
    L3RJ3-6RZ8Y-26LQN-W2AR8-PZ2AD-KG8YD-EMZQG-YYTP5
    i have tried the site but got the wrong code. Any help would be appreciated.
    thanks.
    • jotunn
      • 637
      #77
      Your reset code:
      MFP Serial Number A797021100569
      Reset Code MRQNM-LFGWU-5MBFB-6HQXS-3SGE8-2G8YD-EMZQG-YZDB5
      • wgkingwy
        • Jun 2023
        • 23
        #78
        Hi jotunn, my c22e dont enter SMode
        Please help,thank you!
        Printer serial๏ผšA5C4081101898
        MAC 00:20:6B:AA:6B:E8
        Ce pass request: BAER5-AYWPM-YMXNX-JVYFA-LBXHD-SG8YD-EMZQG-YZDR3
        • jotunn
          • 637
          #79
          Your reset code:
          MFP Serial Number A5C4081101898
          Reset Code MZYVZ-CC5J5-P4CXA-XQL5T-KZWKT-2G8YD-EMZQG-YZDRX
          • wgkingwy
            • Jun 2023
            • 23
            #80
            Originally posted by jotunn
            Your reset code:
            I have successfully reset the password. Thank you very much. Does this reset code have a useful period?
            • jotunn
              • 637
              #81
              The reset code is single-use and only fits a machine with a given serial number.
              The request code needed to generate it is only valid for one week.
              • easycome
                • Jul 2023
                • 4
                #82
                Hello.
                for the bizhub 287 where I lost the service mode password, can you help me recover it?
                thank you
                • jotunn
                  • 637
                  #83
                  Yes, I can.
                  Remember to check if the date and time in your machne are current.
                  • easycome
                    • Jul 2023
                    • 4
                    #84
                    the time and date are correct
                    A7AH021004125
                    00:20:6B:9C:FA:B5
                    CHKJT-BTUX9-65T62-HD5CV-4B6B7-2G8YD-EMZQG-4YDRR
                    Thx
                    the correct code has changed
                    6KNH8-6HX6Q-QVV37-B5G4C-2WNN8-2G8YD-EMZQG-4YTBV
                    • jotunn
                      • 637
                      #85
                      Your reset code:
                      MFP Serial Number A7AH021004125
                      Reset Code 5RR88-L8L8X-WP3FB-2YWTL-W9937-CG8YD-EMZQG-4YTBX
                      • easycome
                        • Jul 2023
                        • 4
                        #86
                        Thank you for help,
                        it doesn't work....the code always changes on restart
                        Now it is
                        W7LUJ-YPZ3R-73T3E-URC6K-P7GD3-KG8YD-EMZQG-4YTB3
                        • jotunn
                          • 637
                          #87
                          That's normal - each time new code is generated.
                          Touch the button [Input Reset Code] on your screen, and enter the code below:
                          Reset Code 7XLQ5-ST6CJ-T7FWA-BABVL-TL87Y-9G8YD-EMZQG-4YTBT
                          • easycome
                            • Jul 2023
                            • 4
                            #88
                            It works.
                            9272x4
                            Thank you very much.....
                            • jotunn
                              • 637
                              #89
                              Ok
                              • furius
                                • Jan 2018
                                • 34
                                #90
                                [QUOTE=jotunn;2048562]Sembra tutto a posto.
                                Ripristina il codice per la tua macchina qui sotto.
                                Ora, vai di nuovo alla schermata di immissione della password, tocca [Stop]->[C] e dovrebbe esserci un pulsante [Reimposta immissione codice] nella schermata di reimpostazione della password CE.
                                2.jpg[/CITAZIONE
                                buongiorno caro. la mia macchina developer +224e si era bagnata e ho cambiato le schede, ora mi da sto errore c-4802 pero nn mi fa entrare nel service mode mi dice password fallita.PHOTO-2023-07-25-18-55-14.jpg
