Konica c224 e can't access service mode
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    #301
    Re: Konica c224 e can't access service mode
    Originally posted by jotunn
    Because reset tool is not intended to use in this way - for just resetting password - this is just side effect of other things done by reset tool.
    Moreover, at least some of the problems with 'forgotten passwords' are due to misuse of the reset tool, which is difficult to admit here.
    One, and only officially supported way to reset CE password is reset code.
    I believe that what happens is that machines are acquired for resale and the technical password of the previous service technician is not known. Regarding the reset tools, it does not cause any problem, it leaves the machine factory and that is even better for those machines for resale.
    Field technician since 1994
    • jotunn
      • 618
      #302
      You still don't understand...
      1. reset tool is not allmighty
      2. reset tool is not available for new machines
      3. reset tool is often used for illegal things, so it's wise idea to limit its spreading
      Additionally, imagine the following situation - you want to "steal" competitors machine at some customer site, but it has a password on it, and is fully configured, do you really want to use reset tool and waste a lot of time to recover full configuration when you can just reset password? So in this case, how do you ask for password reset - do you come here and tell in public, that you want to "steal" someone's machine, or you just pretend that you just forgot password?
      The same in case of doing "illegal things" - will you admit in public that you bricked the machine because you wanted to reset total counter?
      • elmaligno
        • Oct 2009
        • 302
        #303
        1-The reset tool does not reset the counters.
        2-The improper use that can be made of it depends on the user, not on the tool itself.
        3-If someone asks here for the codes to unlock the unknown password and it is with bad intentions, I see much worse that there are technicians who provide this information that is obtained being an official distributor to those who do not have access to it.
        4-Reset tool IS available for new models
        I hope it is clear what I mean.
        • TECNICOKM
          • Jan 2021
          • 4
          #304
          Estimado Jotunn para acceder al modo de servicio.
          MFP SERIAL NUMBER: A5C4011007937
          MAC: 00:20:6B:8B:81:E6
          Reset code: 9JRHP-XXPLS-E5VVS-FCJQZ-5JP2F-6G8YD-ENBQG-QZDLB
          MFP SERIAL NUMBER: A5C4011008813
          MAC: 00:20:6B:8B :BD:FA
          Muchas gracias
          • jotunn
            • 618
            #305
            Muchas gracias
            MFP Serial Number A5C4011007937
            Reset Code HYGJ9-TLXXU-XHGM9-4LP4N-LSCJC-6G8YD-ENBQG-QZDPJ
            MFP Serial Number A5C4011008813
            Reset Code SPP7X-JCLFJ-XDF93-M352J-2T6D6-KG8YD-ENBQG-QZDPR
            Regards
            • BjornUAE
              • Apr 2024
              • 12
              #306
              Good day!
              Can you kindly create a reset code for the following details?
              A5C4141100466
              00:20:68:A9:E4:27
              6PUNF-YYYZK-WKNXU-BDCZJ-8PCNX-CG8YD-ENBQG-QZDH3
              Thank you!!!
              • Synthohol
                Certified Konica Expert
                • 5849
                #307
                perhaps you can bump up his rep as a thank you when it all works again?
                • jotunn
                  • 618
                  #308
                  Originally posted by BjornUAE
                  Good day!
                  A5C4141100466
                  00:20:68:A9:E4:27
                  Thank you!!!
                  Would you like to check your data once again:
                  Failed to verify the CE Password Reset Request Code.
                  The entered CE Password Reset Request Code, MFP Serial Number or MAC Address is invalid
                  Regards
                  • BjornUAE
                    • Apr 2024
                    • 12
                    #309
                    I am sorry!
                    Mac 00:20:6B:A9:E4:27
                    Regards
                    • jotunn
                      • 618
                      #310
                      I am sorry!
                      [ATTACH=CONFIG]62437[/ATTACH]
                      Oh, I didn't notice this error, I was too focused on potential errors in request code.
                      Reset code for your machine:
                      MFP Serial Number A5C4141100466
                      Reset Code LRMJ4-VG4EA-T4MRD-SMF9P-435RV-WG8YD-ENBQG-QZDR7
                      Regards
                      • Boltaction
                        • 92
                        #311
                        Jotunn,
                        I speak for all of us when I say we appreciate all your help! If you are still offering to help with reset codes, I have one locked up:
                        Printer Serial Number: AA7P011004178
                        MAC Address: 00:20:6B:F6:7B:7F
                        CE Password Reset Request Code: DQXMP-9PKWN-SKDLN-NAP2A-4EJEU-WG8YD-ENBQG-QZDRL
                        Thank you!
                        • jotunn
                          • 618
                          #312
                          Originally posted by Boltaction
                          Jotunn,
                          Thank you!
                          MFP Serial Number AA7P011004178
                          Reset Code VDG53-4FFGT-2UCVE-DUCHL-95E6T-SG8YD-ENBQG-QZTBH
                          Regards
                          • Boltaction
                            • 92
                            #313
                            I'm in.
                            I appreciate the help!
                            • OBI
                              • Sep 2019
                              • 6
                              #314
                              Your reset code:
                              MFP Serial Number A8JE011001611
                              Reset Code V9GRQ-XR736-LXPA5-6VT8C-F8KBL-CG8YD-ENBQG-QYTHH
                              Regards
                              The code didn't wrok. Seems like it changed, can we try again please?
                              here's the current info:
                              A8JE011001611
                              00:20:6B:E9 D1:E0
                              4UF77-2GZ2Q-YME44-V5M5A-F2VMX-2G8YD-ENBQG-UYDHD
                              • jotunn
                                • 618
                                #315
                                Fresh code:
                                Reset Code GZEEY-2EBS9-VV58R-RX7YW-PQMC2-2G8YD-ENBQG-UYDLR
