Konica c224 e can't access service mode
  • nikfox
    • Oct 2024
    • 3
    #451
    Printer Serial Number A5C4021032667
    MAC Address 00: 20: 6B: 8B: C8: ED
    CE Password Reset Request Code
    Z9379-7SFKX-TH2HJ-MNLEN-5USQZ-2GBYD-ENBRG-EYDDT
    Thank you
    • jotunn
      • 618
      #452
      Thank you
      Can you check your data once again, there is at least one mistake - 2G8YD - try to find other.
      • nikfox
        • Oct 2024
        • 3
        #453
        Whoops sorry - my fault entirely! Took a photo of the code before I left to look at some other things. I’ve now zoomed in a bit now- my apologies, the eyes are getting old. Try these:
        Serial: A5C4021032667
        MAC: 00:20:6B:8B:C8:ED
        Request code: Z93T9-7SFKX-TH2HJ-MNLEN-5VSQZ-2G8YD-ENBRG-EYDDT
        • jotunn
          • 618
          #454
          It's ok now, here's your code:
          MFP Serial Number A5C4021032667
          Reset Code 32M5Q-FBLP7-MQHK7-2CWTQ-B2LMB-KG8YD-ENBRG-EYDDB
          Regards
          • nikfox
            • Oct 2024
            • 3
            #455
            Regards
            Worked brilliantly- thank you so much!
            • IAN B.C.N.
              • Oct 2024
              • 6
              #456
              MFP Serial Number A61E012001728
              Reset Code QF33M-QQHSV-GU4YB-MWRET-TEEPC-6G8YD-ENBRG-AZTBH
              Regards
              It worked flawlessly, thank you
              • hot_tracks
                • Oct 2024
                • 14
                #457
                Originally posted by hot_tracks
                Sorry for not being clear. I mean I can get up to the service mode login screen (where I have to enter the password). If I try to enter 9272 four times I get the message "Your authentication is currently invalid due to unauthorised access". If I enter [Stop] -> [0] -> [C] it brings up the CE Reset Screen but since serial number is not displayed and date is wrong a reset code cannot be generated by you.
                Hello Jotunn,
                With some luck I managed to regain access to service mode and have changed the default password to 9272 (twice).
                I know this is a bit off-topic but currently the machine reboots to a screen with the 4 sharkfins / bars and a thin orange line at the top (not a screen issue) with the blinking orange status light. I have been in touch with the local KM service guys but they are unable to help and have said that they do not support the machine any longer. Just wanted to know if you would be able to guide me with what else I could try or if I should go ahead and scrap the unit.
                • Master Tech Harry
                  • May 2024
                  • 2
                  #458
                  Hey jotunn, if you could help one more tech out here without ssd support. I also can't get into to service mode. Your help is very much appreciated!
                  sn:A7R0012000267
                  mac:00:20:6B:A1:8D:BD
                  code:PS2PN-P8TQK-M25H3-JXBSD-TJ6WB-9G8YD-ENBRG-EYDDL
                  May the copier God's shine bright on you!
                  Thank you!
                  • jotunn
                    • 618
                    #459
                    sn:A7R0012000267
                    Thank you!
                    Reset code for your machine:
                    MFP Serial Number A7R0012000267
                    Reset Code DTX5B-6SXGL-V9WQY-SRZTV-TJ9PH-2G8YD-ENBRG-EYDDT
                    Regards
                    • femaster
                      • May 2011
                      • 1514
                      #460
                      Hello Jotunn,
                      I would start a separate thread about this to get more eyes on it, but for starters give diagnostic mode a try:
                      https://www.copytechnet.com/forum/te...64#post1368264
                      • Master Tech Harry
                        • May 2024
                        • 2
                        #461
                        Excellent!! That worked. You are the best! I am very grateful for you and this platform!!
                        • hot_tracks
                          • Oct 2024
                          • 14
                          #462
                          Thank you. Will do that.
                          • ayo-works
                            • Nov 2024
                            • 4
                            #463
                            SERIAL NO : 77
                            MAC / 00:20:6B:EA:55:77
                            CE PAS.RES KOD: GKVXQ-8888-3B66C-TWTSE-9HMRB-WG8YD-ENBRG-EYDDX
                            Thank you in advance for your support. I am grateful
                            • jotunn
                              • 618
                              #464
                              Originally posted by ayo-works
                              Thank you in advance for your support. I am grateful]
                              MFP Serial Number AA6W121000760
                              Reset Code N5BZX-X8N5Z-MD4F3-654SN-P3EVB-KG8YD-ENBRG-EYDJD
                              Regards
                              • ayo-works
                                • Nov 2024
                                • 4
                                #465
                                Regards
                                Thank you so much for your support. I'm glad we discovered you!
