Konica c224 e can't access service mode
  • Profibastler
    • Nov 2014
    • 98
    #676
    Originally posted by jotunn
    Reset codes for your machines
    MFP Serial Number A5C4021154053
    Reset Code 55YUZ-LN77N-2JJGK-JRQXK-WQJ7G-KG8YD-ENJQG-UZDNH
    MFP Serial Number A5C2021047467
    Reset Code ZGWUR-9K39L-7CNZM-CQJJ9-DLK9J-2G8YD-ENJQG-UZDNH
    MFP Serial Number A5C4021201661
    Reset Code 9U6HX-C3UTQ-MHS3C-ZQGT9-RNFE5-CG8YD-ENJQG-UZDNF
    Donations welcome
    Regards
    Please help for input the new EC reset codes
    There`s no accepting new codes. After login in Service Mode again, request code will be change.
    Please tell right procedure.
    • khanzr
      • 7
      #677
      Thank you for payment.
      Reset code for your machine:
      MFP Serial Number ACVD042001626
      Reset Code 8VXZH-RCXMD-TQTVQ-KL7MD-52AF8-CG8YD-ENJQG-YYDLV
      If the code does not work, I will generate a new one. Codes unfortunately have an expiry date and this one was generated a few days ago.
      Regards
      You are right this one has expired, I have generated a new one now
      Serial Number: ACVD042001626
      MAC Address: 00:20:6B:FC14
      CE Password Request Code: 7KX8U-BS27H-HC56A-YD8MS-6QF5N-CG8YD-ENJQ6-YYDJZ
      Last edited by khanzr; 1 week ago. Reason: upon a second try it got me to this request code now
      • jotunn
        • 607
        #678
        Try this one - it's based on request code from your screenshot:
        Reset Code 6AGXH-YX7A5-AJ9NF-Z8AEX-A99VN-2G8YD-ENJQG-YYTDB
        Regards
        • jotunn
          • 607
          #679
          Both request and reset codes are valid for no more than a week, so after over two weeks it's hard to expect that reset codes will still work.
          The machine needs to have the current date and time set.
          A new request code is generated by the machine whenever the CE Password Reset procedure is started.
          • khanzr
            • 7
            #680
            Regards
            Thanks it worked, I have another machine also with same problem. I shall get the details and send you the payment for it also
            • khanzr
              • 7
              #681
              Hi again, a similar issue with another of the C266i. I would appreciate if a reset code is provided for this one, thanks
              Serial Number: ACVD1420000187
              MAC Address 00:20:6B:FC:78:33
              CE Password REset Code F9MKP-GT9SF-J66YF-W9ZKC-EYPGC-9G8YD-ENJQ6-YYTDF
              • jotunn
                • 607
                #682
                MFP Serial Number ACVD142000187
                Reset Code GENMZ-PJWPD-ZWTGE-F2LM9-JYWR3-2G8YD-ENJQG-YYTHV
                Thank you for your payment.
                Regards
                • wacko_jacko
                  • Jun 2025
                  • 2
                  #683
                  Can I also ask for the code for my machine (Bizhub C368)? I've just done a donation via PP (my email: p....ski@gmail.com).
                  S/N: A7PV021207095
                  MAC: 00:20:6B:5B:2D:9E
                  CE Pass reset request code: E5722-V9QQ5-84ZXY-VBYD5-78AGE-2G8YD-ENJQG-YYTPP
                  This gallery has 1 photos.
                  • jotunn
                    • 607
                    #684
                    Thank you for donation.
                    MFP Serial Number A7PU021207095
                    Reset Code FH5KH-KZ4N9-HAA44-6VTRT-SVTDD-GG8YD-ENJQG-YYTTX
                    Regards
                    • wacko_jacko
                      • Jun 2025
                      • 2
                      #685
                      Sorry jotunn, looks like the code changed today.
                      • Zoran
                        • 51
                        #686
                        Hi
                        A7PU021008400
                        00:20:6B:A2:38:56
                        RSKCL-5YPWX-3CFDT-YS3JY-VXABT-CG8YD-ENJQG-QYTNB
                        A7AH127000434
                        00:20:6B:3A: D8:41
                        9ELA4-JHCPJ-4PYFT-DP3SX-CQRCV-9G8YD-ENJQG-YYTNL
