Afraid I asked this question here before, but.......
  • Hansoon
    • Sep 2007
    • 3391
    If so, cannot find the answer with the search mode and my apologies if bugging you.
    So, her once again:
    Which one is the Latest & Greatest for the BH-C-284e:
    A5C10Y0-F000-G20-M1
    A5C10Y0-F000-GDR-M1 (00)
    A5C10Y0-F000-GDS-M1(00)
    A5C10Y0-F000-GDT-M1(00)
    A5C10Y0-F000-GDU-M1(00)
    If going alphabetical, it should be A5C10Y0-F000-GDU-M1(00)​
    Correct? Or is there even newer/better?
    Hans
  • Synthohol
    Certified Konica Expert
    • 5891
    always alphabetical progression except weird special FW, id only use special if the machine exhibited the specific symptom it was designed to fix.
    you are correct sir in your hypothesis
    • copyman
      Owner / Technician
      • Sep 2005
      • 4756
      Attached DSCF2775[1].jpg is C284e F/W list on Kon/Min dealer website
      • copyman
        Owner / Technician
        • Sep 2005
        • 4756
        Here is C284e F/W list on Kon/Min dealer website
        • Hansoon
          • Sep 2007
          • 3391
          Thanks guys,
          so
          appears to be the latest, and date 4/7/2022 seems good for such an old machine 😀
          Hans
          • Synthohol
            • 5891
            i think you still have to set the bit switch (219 hex 0?) for SMB 2 scanning if needed.
            someone double check my hex, im so out of practice. and ntlm 1.2 in admin.
            • Duplicator
              • May 2022
              • 255
              Originally posted by Synthohol
              i think you still have to set the bit switch (219 hex 0?) for SMB 2 scanning if needed. someone double check my hex, im so out of practice. and ntlm 1.2 in admin.
              On our machines simply installing GDU-M1 allowed SMB2 to work as long as the client settings were set correctly in Admin mode. If I recall correctly the dip switch was used to force a version of SMB.
              Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
              If I helped you out, please give me a thumbs up! It helps my reputation.
