C250i secure print
  • copyman
    Owner / Technician
    • Sep 2005
    • 4756
    C250i secure print
    Off lease machine. Initialized & settings gone through like I usually do. Everything seems turned off on machine side, but "secure print" is showing in driver for output method, grayed out so can't change. I have an older PC in shop so use universal driver which works fine with other "i" series I've tested. Also a box was popping up when selecting print asking for credentials.
    Stupid question, does the copier change the driver automatically to "secure print"? Weird because I didn't change anything on driver side and like I mentioned this same universal driver works for other "i" series tested.
    Thanks in advance
  • kingarthur
    • 1385
    what happens in the print driver, if you go to "Configure", then "Obtain Device Information" , "Obtain Settings" - will that clear it. Also, in "Obtain Settings" , turn off "Auto" this will allow you to change items in "Device Option"
    • copyman
      Owner / Technician
      • Sep 2005
      • 4756
      Will give it a try and report back. Thanks!
      • Synthohol
        Certified Konica Expert
        • 5891
        also check IP/port, that WSD nonsense is as reliable as condoms made by a porcupine.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4756
          Post revised, Update: I ended up formatting HDD, re-installed latest FW, initialized again and son of a bitch all good! Sucks not knowing what it was but glad it's printing now. The picture was before I did the format, etc.
          Thanks again for the replies
          • copyman
            Owner / Technician
            • Sep 2005
            • 4756
            duplicate
            • Duplicator
              • May 2022
              • 255
              By any chance did you change the function version as part of that process? The function version can play a huge role on some models on how it reports the accessories over SNMP to the print drivers.
              Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
              If I helped you out, please give me a thumbs up! It helps my reputation.
              • rolls.bo
                • Sep 2014
                • 42
                I attach a file of mine to always activate protected printing. You verify that these menus are NOT active.
                Sorry if the file is in Italian, but this is a file generated by me and not by user manuals or technicians
                I hope it helps you.
                bye​
