Help with c2060 print with yellow dots...
  • topimpress
    • Jul 2017
    • 26
    plz can anyone help me for this problem
  • Synthohol
    Certified Konica Expert
    • 5798
    print all gradation patterns. yellow goes on before magenta so is it yellow spots or missing magenta?
      • 22997
      I agree. The yellow remains when the magenta is absent. I'd suspect that your magenta drum is experiencing striction. The clearcoat is worn off the magenta drum in places, and toner adheres to the surface. No light can reach the surface in those areas, and is not developed. If the pattern repeats at 188mm it might be the drum only. If the pattern is more random you may need to do a magenta developer change also.
      • topimpress
        • Jul 2017
        • 26
        Thx for our reply.
        I have printed the pattern.. the problem is only on magenta
        replaced the drum did not solve the problem... u think is developer problem..??
        • khaled_abosere3@yahoo.com
          Head technical support
          • Mar 2012
          • 170
          To be closer for the cause
          did you try to swap corona?
          • topimpress
            • Jul 2017
            • 26
            already swiped... but the problem persist
            • wjurls
              • Feb 2017
              • 494
              Looks like contaminated developer. What is the developing unit count for magenta? If it's at or near one million, change the developing unit as well as the developer.
                • 22997
                I cannot identify a repeating pattern. Could this be generic toner or wrong toner?
                • topimpress
                  • Jul 2017
                  • 26
                  it's original and genuine toner
