Bizhub 368e password
  • patrickjlc
    • Feb 2015
    • 225
    I have a 368e with 30k and I can't get access to service mode or administrator due to incorrect password. Both 1234567812345578 and 9272927292729272 and any of the normal conbinations do not work. Is there a way to crack it or should I just use it for the parts? I know going into service mode with stop -0-C you can get access to it, but it prompts for a password and wont go away to regular copy mode unless you power it off and back on.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4697
    That sucks when someone changes both passwords. Not sure why a tech would do this, if it was a tech. I don't think I've ever changed both passwords except I always change admin password to 12345678.
    You said you tried all the normal combinations, even 00000000? Also 12345678 just once? Or 9272 one time or 9272 x2
    Think there is a reset procedure that was discussed here. I'm sure someone else will chime in.
    • Ziggy
      • Feb 2018
      • 731
      jotunn has helped a lot of techs on this thread
      https://www.copytechnet.com/forum/te...s-service-mode
      • Ziggy
        • Feb 2018
        • 731
        I think this is the only option unless you have access to Konica Minolta tech support
        • elmaligno
          Expert technician KM
          • Oct 2009
          • 302
          Use reset tool
          Field technician since 1994
          • patrickjlc
            • Feb 2015
            • 225
            Yeah, I saw that thread. I'm going to be bringing it back to my shop to get the serial # and mac address for it and see if Jotunn can help me. Because unfortunately the machine is in a pharmacy and can't work there
            • patrickjlc
              • Feb 2015
              • 225
              I got this from a Minolta dealer, but can't see if that is for our machine type
              This gallery has 1 photos.
              • tsbservice
                Field tech
                • 8013
                Looks like different model.
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4697
                  Just use the .tar file reset tool as suggested and you shouldn't have to bring back to shop.
