KM C258 / C308 - C163 Code
  • aberock
    • May 2022
    • 124
    Hi there ,
    can someone guide me in how to replace the mfp board in c258 ?
    i know the step in 4 series but for 8 series prcb is with mfp together .
    there is no option for engine backup.
    I try to swap the mfp board - C163 code appear .
    then i make a replacement for the ssd still same .
    i plug in a789 file to flush it code still remain .
    already load firmware with correct machine type still same . C163 / C164
    Please guide me , i already make 2 machine get the same code
  • copyman
    Owner / Technician
    • Sep 2005
    • 4700
    Did you swap eeprom 1 & 2 from old board to donor MFP?
    • aberock
      • May 2022
      • 124
      Yes already swap .
      • doinbox
        • Jan 2013
        • 109
        What are your machine type settings?
        • aberock
          • May 2022
          • 124
          C258 61
          C308 62
          • doinbox
            • Jan 2013
            • 109
            Originally posted by aberock
            C258 61
            C308 62
            No problem was just double checking. What firmware version are you loading?
            • Synthohol
              Certified Konica Expert
              • 5824
              did you let it reboot by itself 3 times? then you should get a 390 code IIRC then hit restore data.
              ive never gotten a used board to work in another machine ever, always a new or reman board.
              i think there is a way to flush the board itself as we used to get reflashed rebuilt boards from hytec.
              hope im wrong.
              • aberock
                • May 2022
                • 124
                hope im wrong.
                no sir after the reset file the machine still boot up to the code C163
