OFF TOPIC
  • methogod
    • Dec 2008
    • 915
    OFF TOPIC
    what is the most bizarre jam you have ever seen?
    just pulled a tiny Lego man of the duplex on the desktop Konica printer.
  • tsbservice
    Field tech
    • 7910
    Re: OFF TOPIC
    Those ladies called me for paper jams on big analogue Toshiba...it turns out that they forgot a whole knife in the machine from their previous intervention.
    • patrickjlc
      • Feb 2015
      • 217
      Re: OFF TOPIC
      A mouse. Got wedged between gears. Not a fun day...
      Sent from my motorola one 5G UW using Tapatalk
      • ZOOTECH
        Senior member of CRS
        • 3374
          • 22930
          Re: OFF TOPIC
          How about this one on a bizhub PRO951? Look carefully ... it's there. I took the registration sensor off three times before seeing it. The paper is statically clinging to the upper guide plate, and would "dance" ... when I discovered it:
          And this is on a bizhub PRESS 1100. We knew exactly where it was ... that is: in the duplex path under the fuser. It took over two hours to get there. My question is: "... and why do you need to duplex labels? It's just backing paper on the back."
          • kingarthur
            • 1301
            Re: OFF TOPIC
            I think mine has to be a hot cross bun in a clocking in machine, the cleaner took her son into work in a bakery, he got bored...no idea how he managed to get a bun into a slot just about wide enough for 160gsm card....but he did it
            • allan
              RTFM!!
              • 5459
              Re: OFF TOPIC
              A single hair bogged down the paper feed drive on a C35...
              Whatever
              • kingarthur
                • 1301
                Re: OFF TOPIC
                I used to go to a hotel, where the cat used to sleep on the top of their A4 copier, full of cat hair...the cat was also a vicious sod, you couldn't go near the copier whilst it was sleeping, and everyone was too scared to move it, I found out the hard way...deep scratches down my arm
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4524
                  Re: OFF TOPIC
                  A family of mice living on top of the transfer belt at a restaurant. Found one dead being fed into trans belt cleaning blade and other baby mice scattered when I took trans belt out. Needless to say the machine had to be replaced not just for mouse crap & pee everywhere but the wires had been chewed and machine was doing some weird stuff. Hard to believe they can squeeze through a tiny opening to get into copier. Heard they don't have skeleton system which allows them to squeeze through tiny cracks!
                  • suomi
                    • Oct 2008
                    • 152
                    Re: OFF TOPIC
                    The children had copied eggs on a scanner glass.
                    The service call was adf not working..
                    • davidmtupper
                      • Jul 2021
                      • 326
                      Re: OFF TOPIC
                      We had a brand new BH808 the kept having duplex jams and each time it was a screw that had fallen in. Finally figured out that the screws in the the duplex section in the door were falling out on a brand new machine and had to replace that part of the door.
                      • larweedad
                        • 87
                        Re: OFF TOPIC
                        Went to a call for Adf jams. One of the managers saw me pull out a straw from a canned air and he said "Oh that's where it went yesterday."
                        • mojorolla
                          The Wolf
                          • 2570
                          Re: OFF TOPIC
                          Pulled a Christmas decorated acrylic fingernail from a paper tray feed assembly.....in April.
                          • patrickjlc
                            • Feb 2015
                            • 217
                            Re: OFF TOPIC
                            [ATTACH=CONFIG]51714[/ATTACH]
                            [ATTACH=CONFIG]51713[/ATTACH]
                            I get lots of those stuck labels, from customers printing medicine labels.
                            As for that little piece of paper, bought a blower and go to town on every paper path and sensor
                            • patrickjlc
                              • Feb 2015
                              • 217
                              Re: OFF TOPIC
                              And you tell them is not covered by any warranty and they get mad... [emoji2373]
                              Once I had a call for a machine not working, go there and the copier is full of water...
                              Guess that is normal for doing business in NYC
