Bizhub C220 not printing
  • vladimuss
    • Dec 2021
    • 6
    [Misc] Bizhub C220 not printing
    Hello guys.
    I recently bought another one bizhub c220 second hand at 170,000 copies but recently serviced. The machine
    worked great when we tested it. But the person from whom I bought the machine decided to delete my personal files viaphysical format of the hard disk. Now I have three problems.No animation data, it cannot print over the network, and the USB port does not work. Now I can only copy. I chack all the settings, removed the tracking account, checked the life of the consumables, different drivers, different IP addresses and everything described in the instructions. When setting a copy for printing, the button flashes in blue, the fans turn on and nothing happens. after restarting the machine, no print job is registered. I will be very grateful for all opinions
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    Re: Bizhub C220 not printing
    Originally posted by vladimuss
    Hello guys.
    First: Animation data is a file that you lose when format HDD, you must reinstall.
    But the problem is, probably, that you must have one or more consumables at end of life, and after the reset, the machine converts the "NON STOP CONSUMABLES" on service mode to "STOP CONSUMABLES". Now the only solution is locate the ones wich had reaches end of life and replace them.
    Field technician since 1994
    • vladimuss
      • Dec 2021
      • 6
      Please , show me how i can stop consumable life counter?
      I don't have any warnings on the display.
      The life of all consumables is just beginning
      • copyman
        Owner / Technician
        • Sep 2005
        • 4738
        If the life indicators aren't showing any at 0% then rule out that being reason machine wont print. Plus you said you can copy.
        The USB port has to be turned on in admin mode.
        Have you done anything like ping the copiers IP address from the config page? Or if you put IP address in browser will the copier interface page come up? Does the IP, gateway & subnet all match with your network scope?
        Sorry if you don't know how to do any of this you will have to call in a tech or the guy that sold it to you.
        Best of luck
          • 14894
          Please post a picture of the consumabe list. The gauges on this machine work the opposite of what you might think. When the bars are full the assocciated unit is at end of life.
          • tsbservice
            Field tech
            • 8031
            Absolutely agree. View them from web interface (PSWC)
            • copier tech
              • 8193
              Hello guys.
              As others have said if any of the image units are at 0% you won't be able to print however if you update the firmware you can enable printing using a CE mode setting.
              If they have not reached end of life try an 'all clear' in CE mode.
              If you need the firmware & your missing move animation file let me know.
              We offer a bespoke service to supply the most popular printer firmware so please contact us to discuss your requirements.
              • vladimuss
                • Dec 2021
                • 6
                www.printerfirmware.co.uk
                I think I configured the network settings correctly and took a few screenshots. I have created only one administrator and no password to print.
                Thank you very much for your cooperation, how easy it will be for you to send me the firmware and the animation date?
                • copier tech
                  • 8193
                  From the screen shots all your consumables look fine. A lot of parts have been replaced recently or the counters were reset.
                  It is a very simply process to purchase the firmware from us. Once payment has been received we send you our unique link to download the files.
                  • vladimuss
                    • Dec 2021
                    • 6
                    I am sorry for the stupid question, but after entering CE mode, in which exact menu can I do "ALL CLEAR"?
                    • tsbservice
                      Field tech
                      • 8031
                      Should be in system 1
                      • femaster
                        • May 2011
                        • 1515
                        Realize that this does exactly what it says, it clears "all". All settings, addresses, network information, etc.; anything and everything that is user configurable. You will be starting from scratch.
                        • vladimuss
                          • Dec 2021
                          • 6
                          Thank you very much!
                          the problem is solved!
                          • tsbservice
                            Field tech
                            • 8031
                            Thank copier tech he nailed it.
                            • vladimuss
                              • Dec 2021
                              • 6
                              Of course. I always enjoy working with professionals!
                              Thanks!
