Konica Minolta Fiery IC-420 CPU on C450i
  • apollo
    • Mar 2008
    • 182
    Hi Guys,
    Have customer with 2x C450i with 2nd device Fiery removed as giving problems.
    Customers many users, uses Adobe Illustrator and saves files as PDF, and prints direct from Mac's.
    Device with Fiery most time bloks print queue and no other jobs come through, happening randomly from several users looks like if file gets corrupted.
    On coomand workstation file Quequ, when I look file error is PS UNDEFINIED ERROR, OFFENDING COMMAND.
    Once queue blocked no other users can print, all jobs stuck in queue.
    The device C459i with Fiery removed, first page prints with error and jobs goes through.
    Error on page is "Undefined Offending Command: NEW
    STACK AAAAA+B Times /Fontaname.
    Both screenshot attached.
    Latest print drivers have been installed from Fiery EFI, but same isdues.
    At end I have flatted Fiery and installed system.software on Fiery IC-420 and set up again.
    Customer reported after a day same issues.
    Has anHambody had a simular issues please. Feedback much appreciated.
    Starts
    06-02-2025
    Ends
    06-02-2025
  • apollo
    • Mar 2008
    • 182
    If we print file as image print OK as it get flattened.,
    But client wants a long-term.solution.
    • Gaffers01
      • May 2011
      • 334
      Looks like the Font is missing either on the Mac or the fiery!
      • apollo
        • Mar 2008
        • 182
        [QUOTE=Gaffers01;n1618913]Looks like the Font is missing either on the Mac or the fiery!
        Thanks for the Reply, are there fonts files like patches i can install on Fiery
        • doinbox
          • Jan 2013
          • 88
          Long term solution is the customer flattens PDF's is it not?
          "Yes, you should flatten a PDF for printing. Flattening a PDF ensures that all visual elements, such as colors and design layouts, are accurately reproduced when printed, making it ideal for print-ready materials like brochures and posters. Additionally, flattening helps prevent further edits and modifications, which is particularly important for sensitive documents. Overall, it enhances document security and ensures a smooth printing process"
          • apollo
            • Mar 2008
            • 182
            Customer prints file direct @ will visiting this week, will advise , so it’s best to print pdf files as image ? Or any other method to flatten file
            • Synthohol
              Certified Konica Expert
              • 5793
              may i suggest importing the raw job to the fiery,(avoid using a driver completely) to the hold queue, then select it and select process and hold then view it in the preview mode and see if it will print without error if it looks ok on the screen.
              also, you can download and install fonts to the fiery.
