Fiery IC-415 won't connect
  • Brise
    • Jun 2025
    • 4
    Hello, I need your help. I have a Konica Minolta Bizhub Press C1070 printer with a Fiery IC-415. It was working fine, but after a power outage, it shut down, and when I turned it back on, the controller no longer connected. What can I do? Thank you.
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5824
    can you web into it?
    what does the lcd show?
    • Brise
      • Jun 2025
      • 4
      Screenshot_20250603_210343_WhatsApp.jpg The lcd shows 00
      • Brise
        • Jun 2025
        • 4
        These are the images of the printerIMG-20250526-WA0013.jpg IMG-20250526-WA0015.jpg
        • Synthohol
          • Mar 2016
          • 5824
          • Brise
            • Jun 2025
            • 4
            Sorry, I speak Spanish. What does it mean " can you web into it"?
            • Synthohol
              • Mar 2016
              • 5824
              can you access the fiery web page by typing the fiery's IP address in a browser.
              does it show up in command workstation?
              if it opens you may see a video cable error if its a physical issue.
              if you cannot access it with a web browser you may need to reload system software.
              00 is usually a good sign on the fiery, it's FF you never want to see.
              • wjurls
                • Feb 2017
                • 496
                This says that it is ready. The controller seems to be working. Did the IP change?
                This gallery has 1 photos.
                • FredJ
                  • Jun 2019
                  • 9
                  I have a similar problem on a c361i
                  Fiery will connect then after a couple hours to a few days it disconnects then a few hours or days later reconnect it does this nonstop with no human interaction and non stop. I can web in to both the machine and fiery. Fiery shows 00. Have replaced ethernet cables and power brick. Any suggestions?
                  • Synthohol
                    • Mar 2016
                    • 5824
                    try this test.
                    have any pc on the network PING -t the fiery in the background all day.
                    it may prevent it from "sleeping"
                    • copytechman
                      • Nov 2008
                      • 943
                      Does pressing the controller button bring up the fiery screen? Id consider replacing the fiery HDD if its acting irratically. Often a system refresh does wonders on these.
                      Regards
                      A.
