Konica C558 PAT test failed
  • jonbonse
    • Jun 2009
    • 737
    Hi all
    One of our C558 has just failed the pat test with a leakage 1.22mA....
    I havent been to site yet but they say thay have tested with different power cables with the same result.
    They have tested Class 1 and Class 2...
    Has anybody had experience with this kind of issue?
    TIA
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5807
    what is the neutral to ground voltage at the wall?
    • jonbonse
      • Jun 2009
      • 737
      Hi, I will have to check when I get there......
      • jonbonse
        • Jun 2009
        • 737
        ..........Its a substitute leakage of 1.22mA
        • Synthohol
          • Mar 2016
          • 5807
          anything more than 0v may cause the test failure.
          more than .5 volt can cause false codes/jams.
          now that these machines only use 3v instead of 5v at some sensors, 1v through neutral/ground only give a 2v reference to the change and sometimes not enough to trigger the sensor resulting in a jam or SC.
          when machine ran 5v, they were more tolerant to voltage fluctuation, now not so much.
          • jonbonse
            • Jun 2009
            • 737
            I forgot to say that the printer is fully functional...
            • ThisPete
              Too old to care
              • Jun 2014
              • 182
              Some ' interesting ' reading for you here jonbonse: https://www.pat-testing-training.net...ge-current.php (assuming that it's the U.K. "oxford" in your profile...)
              • jonbonse
                • Jun 2009
                • 737
                Thanks ThisPete
                I stumbled across this yesterday... I can only assume the limit on their Pat tester is using an old version say 0.75mA for the Substitute Leakage test.....i will check this when I go tomorrow.....
                Oh, yes Oxford UK
                • ThisPete
                  Too old to care
                  • Jun 2014
                  • 182
                  Sounds like it's time to have that ' why are you still using this company? ' talk.. Good luck!!.. 👍
                  • jonbonse
                    • Jun 2009
                    • 737
                    Yup! 👍
                    • kingarthur
                      • 1336
                      I remember on a Sharp copier training course, many many moons ago, this subject was brought up in the classroom, the instructor said that copiers shouldn't be/didn't need to be PAT tested. I had to go to a customer a few years ago, they had loads of shredders, and they decided to send one of their staff to be trained to do all of their PAT testing on everything in their office. I then got called in to check their shredders, as "they'd all failed their PAT tests". It was clear the person who did the training hadn't a clue what he was talking about. I insisted they got someone in who was "properly" trained, and yes....everything was passed after that
                      • jonbonse
                        • Jun 2009
                        • 737
                        As I suspected, the tester was set to the old limit of 0.75mA!
                        All sorted 👍😎
