konica minolta doc feeder df 624 mylar question
  • brent
    • Nov 2008
    • 1214
    so initially I have been getting quite a few jam code 66-05 which I have learned a ton about today.. so I am in the middle of a situation where my customers
    over the years get a jam in the turn over section and they siimply pull the original out as hard as they can.. and it is bending up that mylar and causing problems so I have a few feeders that I have just replaced and cut the mylar to make it work etc.. I used some info here to see how to get into that turn around section out to replace the mylars? huge job I know.. any thoughts on that procedure?
    I love this site and thank everyone for helping everyone learn etc. thank you
    brent
  • Woxner
    • Jul 2011
    • 851
    Re: konica minolta doc feeder df 624 mylar question
    I leave the mylars out. works just fine. its one long mylar
      • 23009
      I made a new mylar for one. I'm not sure how you're supposed to do it ... but I ended up drilling a hole to access the screw that I could not get out:
      It was a major operation, even then.
      • brent
        • Nov 2008
        • 1214
        thanks guys.. I will see what I can come up with.. I still have these machines in the field they are good for the most part
        lo;
        brent
        • tech51
          • 846
          I agree. As long as you clean off as much of the glue as possible.
          It is possible with a little care to drop it in from the top once the top cover feed section has been removed.
