Konica c454e
  • TSS
    • Jul 2018
    • 32
    Konica c454e
    Hello everyone.I was having a 9401 on c454e.I replaced a use ccd unit and got rid of the code,but now it's blurry when scanning or coping on the glass.Prints are good.I tried ccd calibration,just not sure what steps to take after replacement.Any help I would greatly appreciate. I did look at the manuel but it wasn't clear to me.I took the old ccd unit out of a c364e.
  • Synthohol
    Certified Konica Expert
    • 5841
    . For the rest of the mounting procedure, reverse the order of removal.
    5. Reinstall the original glass.
    6. Turn ON the main power switch.
    7. Carry out the [Service Mode] -> [System 2] -> [CCD Calibration].
    8. Carry out the [Service Mode] -> [System 2] -> [Line Mag Setting].
    9. Carry out the [Service Mode] -> [Machine] -> [Printer Area] -> [Paper Feed Direction Adj.].
    10. Carry out the [Service Mode] -> [Machine] -> [Scan Area] -> [Main Scan Zoom Adj.]. If the specifications are not met, loosen the CCD
    board mounting screws and move the CCD board in the sub scan direction as necessary.
    NOTE
    • Hold the CCD board by hand when moving it. NEVER use a screwdriver or similar tool to tap to move it, as a varied distance
    between the CCD sensor and lens results.
    11. Carry out the [Service Mode] -> [Machine] -> [Scan Area] -> [Scanner Image Side Edge]
    • Ziggy
      • Feb 2018
      • 761
      Hopefully you didn't move any of the screws that had red paint on them.
      • TSS
        • Jul 2018
        • 32
        No,Did not touch the red screws.
        • ThisPete
          Too old to care
          • Jun 2014
          • 212
          Do the CCD's have the same part number?
          • Ziggy
            • Feb 2018
            • 761
            I just checked they do have same part number
