Bizhub 423 3001 jam - suspecting wrong tray 1 paper feed assembly
  • tsbservice
    Field tech
    • 7927
    Re: Bizhub 423 3001 jam - suspecting wrong tray 1 paper feed assembly
    You did same firmware as machine is currently on, what else will you expect?
    • Techalyzer
      • Mar 2022
      • 26
      I tried to update from A1UD0Y0-0100-G00-D6 to A1UD0Y0-F000-G00-D6... are these the same?
      • Hap
        • Jan 2017
        • 31
        Originally posted by Techalyzer
        Someone did get the registration assembly out. It was me, multiple times. The mylar is just fine. As I stated above, for tray 2, the blockage now occurs at the 2 big rollers above tray 2 feed, as if they don't turn. Again, as I stated above, and I quote, "all clutches are BRAND NEW, and mechanically everything is perfect, all sensors are cleaned, everything is perfectly clean, lubricated, nothing is dirty or stuck or worn out". This is by far the cleanest, least worn out machine I have ever seen. The thing is literally new.
        Anyway, it's getting late here, I'm going to sleep and tomorrow I'll probably try a firmware update. A big hint is that apparently we have another 423 with the exact same issue.
        the mylar can be fine but it can go over or under the guide it should be over the reg assem
        • Techalyzer
          • Mar 2022
          • 26
          #19
          If words don't work, let's try pictures.
            • 22954
            #20
            Not that mylar. This mylar:
            • Techalyzer
              • Mar 2022
              • 26
              #21
              [ATTACH=CONFIG]52432[/ATTACH]
              You have to be more specific, I have no idea what that is, nor does it look like anything I've worked with and it doesn't seem to be from a service manual.
              • Hap
                • Jan 2017
                • 31
                #22
                [ATTACH=CONFIG]52430[/ATTACH]
                This is the mylar i was referring to ,easy to get it tucked under
                  • 22954
                  #23
                  I'm complimented that you think that I drew this myself ... but I did not. Take a look at your Theory Of Operation Manual > Registration Section. =^..^=
                  • Techalyzer
                    • Mar 2022
                    • 26
                    #24
                    I don't have such a thing, never heard of it before, and Google doesn't help either. I have service manuals and parts manuals.
                    Yes, it is easy to get it tucked under indeed. But as you can clearly see, it isn't, is it?
                    • femaster
                      • May 2011
                      • 1469
                      #25
                      Theory of Operation is a part of the Service Manual.
                      • Hansoon
                        • Sep 2007
                        • 3355
                        #26
                        The feed units are NOT interchangeable.
                        +1
                        Happened here several times when colleagues put the wrong labels on prepared units we have in store. We always have at least 2 pcs each of rebuild units in stock for these series. I started to mark the units for the slow series with large yellow dots and for the BH-423 with a red dot. Similar procedure for the BH-C-280/360 series where those feed units are also not interchangeable.
                        Hans
                        “ Sent from my Intel 80286 using MS-DOS 2.0
                        https://www.copytechnet.com/images/smilies/biggrin.png
                        • Techalyzer
                          • Mar 2022
                          • 26
                          #27
                          Well, it seems it is not part of my manual, these are the only references to the word "Theory" I can find in my manual.
                            • 22954
                            #28
                            On this model the Theory Of Operation is a separate document. It's not part of the handbook.
                            Just look at the registration rollers. the mylar touches the metal registration roller. =^..^=
                            • Techalyzer
                              • Mar 2022
                              • 26
                              #29
                              Just to make it clear, we do not have any physical manuals, we only have what you can get online doing a Google search. And Google has absolutely nothing when I search for "bizhub 423 Theory of Operation".
                              Are you talking about the mylar from that thing that gathers paper dust?
                              • Albonline
                                • Sep 2008
                                • 1135
                                #30
                                Hello,
                                I have this weird problem with a Bizhub 423. At every print from tray 1, the paper jams, sometimes at the first sheet, sometimes after a few sheets. Always jam code 3001. 537K copies on the machine. I have found a similar thread here, and it mostly points to the paper exit assembly cable/connectors or the wrong type of paper feed assembly used for tray 1. I have checked the imaging unit, registration unit, fixing unit, paper transport, it all looks perfect, one of the best looking machines I've worked on, minimal to inexistent wear, nothing wrong mechanically.
                                And indeed, upon inspection, the tray feed assembly is the usual kind you find on other slower models, 3 sensors, 3 extra free pins on the main connector probably left for the missing sensor.
                                The catch is this: it's only my 4th day in this company and obviously I don't want to seem to be... "that guy". The person who deals with it says that's how it was before, with that same tray 1 paper feed assembly, and it worked just fine. I somehow doubt that, you can see the feed assembly clearly in the parts manual and it's not what we have here. But... being my 4th day, I'm really reluctant to start contradicting with people during my first week.
                                Any advice?
                                I don't know if anybody mentioned the drive motors just slow down in this series. try exchanging the main drive with the developer drive motor. this problem happens sooner on the faster models in this series.
