KM Bizhub C221
  • pasion1
    • Nov 2020
    • 15
    KM Bizhub C221
    Error c 3101. What could be the cause and if any part of the fuser needs to be replaced. Thanks
  • copyman
    Owner / Technician
    • Sep 2005
    • 4723
    Re: KM Bizhub C221
    I don't see a C221 listed on Kon/min dealer website, unless I missed it? There is one for sale on Ebay so it appears to be real model #. Weird I don't see it on K/M dealer site.
    FYI most Kon/Min fusers are sold as a complete unit, no separate parts sold.
    • pasion1
      • Nov 2020
      • 15
      Re: KM Bizhub C221
      It's like the bizhub C364.
      I reset and that code reappears
      • femaster
        • May 2011
        • 1514
        Re: KM Bizhub C221
        If it really is like a C364, here is the error information. Remember, the part numbers it's talking about might not be the same for the C221 model, so use this as reference info only.
        Trouble type
        Fusing roller separation failure
        Trouble code
        C3101
        Rank
        B
        Detection timing
        • With the fusing roller being retracted, the fusing pressure home sensor (PS38) is not unblocked even after the specified period of time has passed after the fusing pressure motor (M11) started rotating.
        • With the fusing roller being pressed, the fusing pressure home sensor (PS38) is not blocked even after the specified period of time has passed after the fusing pressure motor (M11) started rotating.
        Trouble isolation
        Relevant electrical parts
        • Fusing pressure motor (M11)
        • Fusing pressure home sensor (PS38)
        • Printer control board (PRCB)
        • Fusing unit
        • Synthohol
          Certified Konica Expert
          • 5849
          Re: KM Bizhub C221
          looks like a 28e to me
          • femaster
            • May 2011
            • 1514
            Re: KM Bizhub C221
            Yeah, was late so I didn't bother to try and track down a picture of a C221. I was assuming the OP actually knew what they were talking about, but I guess the old adage about not assuming anything applies here. That thing doesn't look anything like a C364. Can almost guarantee that tiny little junker doesn't have a pressure roller release system for the fuser, so the code info I shared will be completely worthless to the OP.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4723
              Re: KM Bizhub C221
              If you reset code and it comes back then replace the fuser.
