Envelope icon in Service Mode?!
  • Methmann
    • May 2009
    • 79
    Hello
    Do any of you know, what a envelope with a cross icon means in Service mode??
    I have checked and reset CS Remote Care, so it doesnt seem to be because of that
    Thank you :-)
  • kingarthur
    • 1383
    What happens if you press it.....
    • Methmann
      • May 2009
      • 79
      Unfortunately, nothing happens
      I have also tried to do a clear all data, didnt help either
      • Synthohol
        Certified Konica Expert
        • Mar 2016
        • 5878
        its the email transfer icon. or failed in your case
        maybe vcare or maint reporting has been setup and it was unable to send the data through the network for some reason.
        • Methmann
          • May 2009
          • 79
          Do you happen to know where/how to disable it??
          • Synthohol
            • Mar 2016
            • 5878
            in admin mode under network setting, detail setting, total counter notification
            • tsbservice
              Field tech
              • 8041
              Originally posted by Methmann
              Hello
              Thank you :-)
              How exactly did you reset CSRC?
              Step by step please.
              • Synthohol
                • Mar 2016
                • 5878
                Data Initialization clears the Server Settings of CS Remote Care not its use.
                do a ram clear and initialize in cs care
                just undo anything this says.
                start by disabling webdav.
                • Methmann
                  • May 2009
                  • 79
                  First, I noticed that the "Start Maintenance" button wasn’t visible under CSES — it’s usually there if CSES is set up.
                  But I went in anyway and pressed "RAM Clear" for all items (email, HTTP, etc.), using the ID code "1111111", and finally went into Server Settings and selected "Data Initialization".
                  Exactly as I’ve always done — I’ve disabled CSES on many machines before.
                  But I have never, ever seen such an icon, not even on machines where CSES was enabled.
                  • Methmann
                    • May 2009
                    • 79
                    Checked that, it is not set up. And if it had, it should also be disabled, when doing an all data clear
                    • Synthohol
                      • Mar 2016
                      • 5878
                      well those were the only 2 things that email home by itself that i know of.
                      sorry.
                      • Methmann
                        • May 2009
                        • 79
                        sorry.
                        It was also my first thought. It´s strange :-(
