OAuth2.0 authentication on 8 series
  • tsbservice
    Field tech
    • 8081
    Hi guys, according to Bulletin 14221 for bizhub 7, 8, & 9 Series G00-YE Maintenance Firmware Release
    There is mentioned this:
    Additional Functionality
    OAuth2.0 authentication is supported. Please reference KB0032920 for information regarding using the newly added
    OAuth2.0 functionality.
    Kindly can anyone share KB0032920?
  • copier tech
    • 8236
    Here is the European bulletin if it's of any help. Lists the 29 bug fixes.
    Bizhub C258 C308 C368 FW Read Me G00-YE.pdf
    About OAuth2.0.pdf
    • kingarthur
      • 1399
      I've installed the FW onto a C308, but when I go to the SMTP settings, I can't see OAuth anywhere, like it is on the iSeries - that's actually standing at the device, not through pagescope
      • Duplicator
        • May 2022
        • 271
        Same here. Tried it out but the instructions we have from Konica are for an i-Series and refer to menus/buttons that don't exist on an 8 series. Tried Page Scope as well. Either I'm missing something basic or there is some unmentioned dip switch to set too or something.
        Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
        If I helped you out, please give me a thumbs up! It helps my reputation.
        • copier tech
          • 8236
          After updating to GC2-RF set the function version to 2.3.
          • Duplicator
            • May 2022
            • 271
            2.3 is the latest for the i-series stuff. According to the release notes 4.2 is the latest function version for the 8 series.
            For what it's worth...the machine I was testing with was on 4.2.
            • Max
              • Oct 2011
              • 575
              Same here. Not very clear on how to enable it.
              • Sarg
                • Sep 2019
                • 8
                Don't worry, even though my device has OAuth 2.0 settings after installing G00-YE (probably OAuth because I can't be sure what that is 😁), all the buttons are blank anyway ¯\_(ツ)_/¯
                I tried different languages but still the same result.
                This gallery has 3 photos.
                • Slammers
                  • Feb 2019
                  • 187
                  Is there anything new in the webinterface that you can see?
                  Does it a have a separate sub menu under Network -> OAuth or something like the OpenAPI stuff? It may need the SSL Cert applied to it under protocol.
                  Is the web browser enabled on the machines you are testing on?
                  I wonder if the 8 series uses the App API settings like the Kyoceras, so may have to test creating an app connector in the Entra Admin Centre and using Client ID, Tenant ID and Secret.
                  I won't have access to this FW release until October as Olivetti are always delayed so I can't test for myself.
                  • Sarg
                    • Sep 2019
                    • 8
                    You can't set OAuth through web interface on 8 series so no in that regard.
                    But even if certificate is needed that shouldn't make buttons blank, am I right?
                    Yes, the browser needs to be enabled. That's probably the issue that the guys in the previous posts have.
                    • copier tech
                      • 8236
                      What if you set this setting to enable ?
                      • Sarg
                        • Sep 2019
                        • 8
                        If I recall correctly nothing. It's just one of the options. The main on/off switch is in the first photo. Setting up the email settings and clicking one of the buttons with an arrow in the lower right corner will direct you to the MS/Google authentication site. I suppose it's possible with the trial and error method, but installing a machine like that in the field and having the customer set up his own email like that is not acceptable to me.
                        • Slammers
                          • Feb 2019
                          • 187
                          Thank you for the replies and insight. Hopefully this gets ironed out soon. Have a fair few 8 series at clients that will need this update.
                          • Duplicator
                            • May 2022
                            • 271
                            Can confirm, that is the piece I was missing. Just tried it again but enabled the browser. I am able to see the OAuth2 settings now. I was able to reach the Microsoft OAuth login page.
                            • Sarg
                              • Sep 2019
                              • 8
                              So the buttons in OAuth settings on your machine are not blank? Which model is this exactly?
                              I thought it was a bug in the FW and that it would behave the same on every machine. I even tried installing G00-YE on another C368 and got the same result.
