Bizhub C558 will only receive fax even if trying to manual send
  • ndlovu
    • Nov 2013
    • 21
    [Misc] Bizhub C558 will only receive fax even if trying to manual send
    I have a C558 which every setting is "correct" and the "market area" is set correctly (USA). I have done an initialization on the fax, removed it and added it back. The unit still wants to only receive faxes even if I try to manually send a fax. There is no "send" button only a "receive" button. In "direct input" there is no "Fax" button. Any ideas or pointers would be greatly appreciated.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4654
    Re: Bizhub C558 will only receive fax even if trying to manual send
    That is weird. It almost seems like there is setting not allowing to send. I've never seen that except not having correct marketing area which you have set correct. Just got an 8 series in shop and will look. If I find anything will report back.
    • tsbservice
      Field tech
      • 8000
      Easy. Initialize machine and setup fax board.
      • femaster
        • May 2011
        • 1491
        Any kind of account track or authentication turned on? If so, the "public" user may be restricted from using the fax function.
        • ndlovu
          • Nov 2013
          • 21
          There is no account track or authentication turned on.
          • ndlovu
            • Nov 2013
            • 21
            Machine was initialized with the fax board in it, would I still need to setup the fax board?
            • kingarthur
              • 1338
              Is the HDD set?
              • ndlovu
                • Nov 2013
                • 21
                Originally posted by kingarthur
                Is the HDD set?
                HDD is installed and as far as I know formatted.
                  • 23002
                  I had a weird one like this on a Toshiba Weisshorn High. In the end, it was caused by a security conscious IT guy that who browsed through the web interface unchecked everything he did not understand. That included "Enable Fax Tx", and "Rx fax without printing". Yeah, I brought a spare fax board, but it made no difference. =^..^=
                  • avecosat
                    • Jun 2012
                    • 305
                    Marketing area is US and Fax Target is also in US ?
                    • emujo2
                      • Mar 2017
                      • 1579
                      Had this issue a few years ago..There was a solution (Equitrac, Output Mgr, ect) installed on the device..Once installed the solutions OPEN API settings determined what was shown on the screen. Ed
                      • minoltaed
                        • Aug 2009
                        • 44
                        Did you try to turn off dial tone detection? I have seen this cause issues.
                        • davidmtupper
                          • Jul 2021
                          • 326
                          This may or may not be applicable to this situation, but the early i series KM copiers had fax send disabled from the factory. It needed to be enabled under administrator. Not sure if some of the later 8 series had the same issue, but it sounds like the same symptoms.
                          • ndlovu
                            • Nov 2013
                            • 21
                            Yes they are both set for US
                            • ndlovu
                              • Nov 2013
                              • 21
                              How do you enable send under the administrator?
