Turned on Hard disk by mistake bizhub 266 won't turn on
  • Wasi7890114
    • Apr 2022
    • 7
    [Dead] Turned on Hard disk by mistake bizhub 266 won't turn on
    Dear brothers
    One of my technical person turn on harddisk from settings on bizhub 266 color machine there is no option for hardisk now when i turn on the device its stuck wont turn on not showing any error code just blue first display shows and not getting startup its looking for harddisk i think but there is no port for hardisk how i can reset the defaults or how i can fix this issue when i use another rom its turn on but i dont have the same rom for device can you please help me
  • tsbservice
    Field tech
    • 8010
    Re: Turned on Hard disk by mistake bizhub 266 won't turn on
    Originally posted by Wasi7890114
    Dear brothers
    We don't have bizhub 266 model whether is colour or not. Could you be more specific?
    • Wasi7890114
      • Apr 2022
      • 7
      Sir. This is c266 konica minolta color printer i just turned on harddisk from printer setting this printer doesn't port for harddisk it have a chip EVOROM. sir When i switches on the but in panel screen it only shows processing icon and no other key works... And it keeps displaying processing icon till end...
      • copier tech
        • 8144
        Dear brothers
        Can you enter CE mode & unset the HDD again ?
        • Wasi7890114
          • Apr 2022
          • 7
          No bro i can't enter in CE mode its stuck on processing.
          • rrrohan
            • Sep 2011
            • 1977
            it looks like its same series as a C227
            you should be able to enter CE mode via trouble reset
            Hold down reset while turning on with main power - when black dot in corner appears let go of reset button - when trouble reset appears do the stop 0 stop 001.
            turn off HDD again
            im kinda surprised any copier these days can come without a HDD but we dont sell this model in my region
            • allan
              RTFM!!
              • 5462
              Also did not know. Its looks much the same as a C227. Horribly expensive machine to run!
              Please let us know if rrrohan's advice helped you.
              Whatever
              • Wasi7890114
                • Apr 2022
                • 7
                turn off HDD again
                Dear Its not appearing for any CSF mode or any other display its stuck on loading screen .
                • Wasi7890114
                  • Apr 2022
                  • 7
                  I tried as you say but notthing appearing ..
                  • Wasi7890114
                    • Apr 2022
                    • 7
                    Dear sir still same issue
                    • femaster
                      • May 2011
                      • 1504
                      Since it appears that none of the other advice seems to be working, maybe the easiest thing would be to source a HDD out of a parts machine of some sort, connect it up, and hopefully it will at least boot then. If it gives you a service code, probably not a big deal, as you are just looking to get it to boot so that you can unset the drive.
                      Then it should just be a matter of going back in and unsetting the HDD, powering down, and disconnect it. If it really is similar to the C227, you could pull a HDD out of just about any model from the xx3 series on up to the xx8e models. As long as the drive is either a 250GB or 320GB with SATA connection, you should be good to go.
                      • dansaints
                        Printer Technician
                        • May 2024
                        • 30
                        Dear brothers
                        Good day here. I am experiencing the same issue on the same model. Also tried doing trouble reset but no results also.
                        Has your issue been resolved? Please let me know.
                        • copier tech
                          • 8144
                          Can you power on the device in trouble reset mode? Then enter CE mode from that screen to disable the HDD.
                          • dansaints
                            Printer Technician
                            • May 2024
                            • 30
                            Unfortunately I can't go to trouble reset mode. It's just stuck in the loading screen.
                            • copier tech
                              • 8144
                              OK, have you tried from the firmware update screen ?
