C458 scanning issue ??
  • tsbservice
    Field tech
    • 7977
    Re: C458 scanning issue ??
    Originally posted by KMFLT3CH
    nah the screenshot is an 8 series still running very old firmware. the pagescope layout changes to the black/grey scheme after a certain function version, hence the newly delivered machine that OP posted about is running newer firmware than the other 8 series already on site.
    OP, make sure base firmware is up to date, version G00-X4 should be new enough considering their other machines are still on much older firmware. double check the function version, should be switch 25 / HEX B0 (zero)
    lastly, usb export the network settings of a working 8 series already on site and import it into their newer machine, give the machine an IP address, then try scanning.
    A bit late to the party, aren't we
    • KMFLT3CH
      • May 2017
      • 226
      yeah seems a few of us in this thread are, what's your point? just confirming that OP was not mistaken with his screenshot, carry on.
      • tsbservice
        Field tech
        • 7977
        My point is in my replies, you're entitled to disagree. Carry on.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4627
          #19
          Update the firmware & set the function version to 4.2 & start from there.
          I bet you'll find this is all that is needed.
          IT WORKED !!! THANK YOU !!!
          And thanks to everyone else who replied. I really appreciate the help.
          If anyone else has more requests for "All solutions" post in other thread and I will post them for you. I like to pay it forward....
          • Reed
            • Feb 2011
            • 259
            #20
            Originally posted by copyman
            Yes they setup most of my machines remotely.
            They said all their 4 & 8 series web interface pages look same. Attached is pic of a C558 in their office, web page looks same as "4" series. This is first time seeing this web page? Not doubting there are different pages for new machines just mentioning it as might help with the scan issue.
            When the "version" is changed through software switch 25, It will change the web interface. Usually "version" is changed (ex 3.2 to 4.2) it is done when the FW is upgraded
              • 8132
              #21
              Thanks for the feedback.
              Once again proves the importance in keeping the firmware up to date.
              Printer & Copier Firmware - www.printerfirmware.co.uk
