BH C454e - Scanned Image Issue
  • D Colour
    • Oct 2008
    • 217
    [CQ] BH C454e - Scanned Image Issue
    Hi
    Have a strange issue on a C454e were it is putting a dotted line on scans. It happens on scans through the dual scan DF (tried dual scan board and another DF) and on the glass, single sided and duplex originals.
    Fault does not occur on copies through DF or on glass. Prints are also fine. So its not optics or consumables.
    Scan Sample2.pdf
    Scan Sample.pdf
    Dots look digital and run edge to edge, portrait or landscape.
    The problem seems to be related to grayscale only. It does not occur when you scan in black or in colour. Have set machine up to default scan in colour for now.
    Tried scanning in as PDF, compact pdf, jpeg and tiff. All have the dots.
    Ran self diagnostic in service with no faults showing.
    What could be adding these dots onto the digital image in grayscale (and why!)? Faulty memory or HD?
    Running the latest standard firmware at G20-M1.
    Thanks for any help!
    Everything that has a beginning, has an end.....
  • tsbservice
    Field tech
    • 8109
    Re: BH C454e - Scanned Image Issue
    What if you disconnect DF and its board and scan of the glass(DF is only like original cover)?
    Maybe I will make HDD logical format if problem persists.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4828
      Originally posted by D Colour
      Hi
      [ATTACH]53467[/ATTACH]
      [ATTACH]53468[/ATTACH]
      Just when I thought I saw it all! Really weird the dots are perfectly spaced apart like. Only thing different when scanning is doc feeder runs faster. Perhaps something with the CCD unit & scanning?
      Sorry wish I could be more help.
      • femaster
        • May 2011
        • 1532
        Not really sure what might be causing that, but try running a scan at 200dpi and one at 600dpi through the ADF. The ADF will run faster at 200dpi and slower at 600dpi. See in the spacing between the dots is different at each speed.
        • copier tech
          • 8275
          Hi
          Dude this document has your clients mobile number, email & site address. I would take this down ASAP & use another document!.
          โ€‹
          • copyman
            Owner / Technician
            • Sep 2005
            • 4828
            I was thinking that too but not really any critical information. Free advertising! All that information can be found publicly or on a business card.
