Konica Minolta C284e Misfeed detected. 32-01
  • mearmi
    • Oct 2010
    • 350
    [Jamming] Konica Minolta C284e Misfeed detected. 32-01
    Hi
    Konica Minolta C284e getting Misfeed detected. 32-01.
    Paper just folds before fuser rollers in the fuser. Doesn't exit from the fuser.
    Replaced the fuser and Registration Unit. Could be Fuser Drive Motor?
    Kindly advise. Many Thanks
  • Gift
    • Mar 2011
    • 2459
    Re: Konica Minolta C284e Misfeed detected. 32-01
    Does ist happen all the time with the first page?
    I recall that the gate above the fuser can cause this (if it's sticky) but then it shouldn't stop before the fuser. I think the fuser drive is unlikely but you can check if it's operational with a little mark on the roller or watch it with a cheated side door switch. You might also take a look at the sensors and test them.
    • tsbservice
      Field tech
      • 8020
      If it was gate on first page of duplex then paper will exit instead of reverse. If it does it jam also on single sided I would replace CL8(exit clutch).
        • 23009
        A stalled primary transfer belt will create this jam. =^..^=
        • Toxic
          • 698
          Let me have a try...
          2nd transfer paper winding prevention guide missing?
          • Gift
            • Mar 2011
            • 2459
            Originally posted by harigabi
            I have the same situation. The error occurs only with duplex prints with codes j32-01 and j32-05. I replaced the exit unit a year ago, now it's doing it again. I took out the small sponges from behind the gate so it wouldn't get stuck. Now the error is only j32-01 and, according to the customer, only for duplex printing and in a cooled state. When I'm there, the paper never gets stuck, but I can see through remote monitoring that it gets stuck several times a day. Bizhub 364e
            Check if that duplex entrance/conveyance assy (located on the inner/top area of the right door) has all modifications - I think the modified one has some plexiglass parts
            • kingarthur
              • 1369
              Those "small sponges" need replacing, i carry them with me. there are 2 in the door and 2 on the reversal unit.
