ripple effect
  • Sharptecman50
    • Aug 2017
    • 6
    [CQ] ripple effect
    I have a konica C454e that paper comes out of copier with the last half of page with a ripple effect, i have done the following. replaced fuser twice, exit assy, fuser drive pack. I have added a wrap on loop spring, i have tested every size of paper and every tray. i have taken finisher and bridge out of loop and yet still get a ripple effect, dows anyone have any other thoughts.
    • 23010
    Re: ripple effect
    The exit assembly should have solved it. It's known on these machines that the exit bushings begin to seize. It seems to affect internal finishers more than external finishers or exiting to engine top.
    Try this: set the media type to Thick4. If the problem goes away, it's because the machine turns slower on Thick4.
    • Sharptecman50
      • Aug 2017
      • 6
      Re: ripple effect
      Thankyou I will try that
      • Woxner
        • Jul 2011
        • 852
        Re: ripple effect
        See if fuser speed helps solve this
