external memory
  • James0221
    • Aug 2022
    • 5
    external memory
    after the firmware update for the bizhub c284e, there was an error for external memory. any solutions? should i replace the ram or the motherboard? thanks!
  • Synthohol
    Certified Konica Expert
    • 5840
    Re: external memory
    with or without the flash plugged in?
    • Ziggy
      • Feb 2018
      • 761
      Re: external memory
      Make sure you have correct firmware on the usb stick if it is try another usb stick
      • Kenny
        • Jun 2009
        • 529
        Re: external memory
        generally happens when the firmware update didnt complete properly, run the firmware again and see which part failed
        • Albonline
          • Sep 2008
          • 1151
          Re: external memory
          you may have to run the board reset tool. Then do just the mfp firmware.
