Brand new Press 6120 and Fiery MIC-4160
  • copytechman
    • Nov 2008
    • 947
    Hello all!
    Looking for a piece of a puzzle, of course installation instructions aren't perfect but I have a brand new Fiery installed on a new KM press 6120.
    Printing works, can see the fiery via web page, but when you press controller on the device I get a blank white screen that eventually times out to a page not found error.
    the fiery is connected to the device via the video cable (from the video board to the connector on the fiery, with that odd shaped hdmi cord and the network cable is connected to the net connector on the fiery (copier symbol) and the net connector on the newly installed video board, if you unplug the net connector the fiery immediately notices.
    also dip sw 40-7 is set to 0 for the fiery.
    What am I Missing?
    Regards!
    A.
  • tulintron
    • Jul 2014
    • 668
    Re: Brand new Press 6120 and Fiery MIC-4160
    Originally posted by copytechman
    Hello all!
    What am I Missing?
    Regards!
    A.
    Did you install the VI-509 kit?
    • tulintron
      • Jul 2014
      • 668
      • copytechman
        • Nov 2008
        • 947
        Yes the vi-509 was installed , followed all instructions per vi kit and everything else. At least until the fiery refused to even turn on now. Go figure. Appears dead now . No nothing
        • Ziggy
          • Feb 2018
          • 768
          I know that its a new Fiery but check the fan on the cpu and make sure its spinning free.
          • PrintWhisperer
            • Feb 2018
            • 473
            Did you enable IPv6 on the copier and set it to DHCP? The Fiery should configure the mfp for communications. This is how all the Kyo Fierys talk to the mfp, the video cable is just RIP data.
            "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
            • copytechman
              • Nov 2008
              • 947
              • copytechman
                • Nov 2008
                • 947
                I will double check that too , thank you.
                Regards.
                A.
