Bizhub C454 colored stripe
  • copyman
    Owner / Technician
    • Sep 2005
    • 4651
    #16
    Re: Bizhub C454 colored stripe
    It's not that cleaning problem that "creates" that line, it's the patches the laser is writing to calibrate. It's not cleaning the rest of the belt either, it's just a lot more noticeable when there is 300% fill, than when there is < 1% fill. =^..^=
    So looking at this logically, the OP is able to wipe the calibration band off the belt, doesn't clean the waste out of the trans belt cleaning unit and is able to run another 500 pages before it appears again. Please explain how this is possible?
      • 23002
      #17
      How often does it calibrate (make patches?). What if those customer images had very light fill ... 3% or less?
      Which is more likely?: a blocked up waste toner spout, or an MFP board randomly generating calibration patches in the middle of the image?
      I think I'd start with the known issue, that's far more likely. =^..^=
      • copyman
        Owner / Technician
        • Sep 2005
        • 4651
        #18
        I was thinking the same thing about when does it calibrate. I would think it would auto calibrate when voltages change from the 2 trans belt IDC sensors as well as when coming out of sleep mode or when first turned on with main pwr sw.
        I've serviced hundreds upon hundreds of the 4 & 4E series from the c224 Non E to the C754E over the last 10 years and have never seen this issue. As strange and odd as it is still think it will turn out to be something like a board. Most likely the MFP pwb
        Hate to beat a dead horse but no way I can see the exact same "straight edged" calibration strip in same place every time from a clogged waste toner or clogged trans belt cleaning unit.
        Hopefully the OP will post the fix. I'm always open to learning something new
        • Synthohol
          Certified Konica Expert
          • 5808
          #19
          it gets on both sides usually because the belt leaves the stripe on the transfer roller and acts like a press
            • 14586
            #20
            If you look closely you can see the edge erase. This means the band is being printed onto the page and it's unlikely it is a cleaning problem.
            • copier tech
              • 8133
              #21
              The fact that if you rotate the bely by hand & it doesn't clean the line off the belt is odd.
              Are you using genuine Konica Minolta toner ?
              No response to the genuine toner question ?
              • tsbservice
                Field tech
                • 7995
                #22
                Originally posted by cristachecri
                [ATTACH=CONFIG]55801[/ATTACH][ATTACH=CONFIG]55801[/ATTACH][ATTACH=CONFIG]55801[/ATTACH]
                I have a Bizhub c454 that has a problem. It removes a colored stripe that is visible on the belt and which the belt cleaning blade cannot clean. I replaced the transfer belt with a new one and the defect persists. I mention that he uses only original toners.
                It's in initial post.
                • Hansoon
                  • Sep 2007
                  • 3376
                  #23
                  • cristachecri
                    • Mar 2015
                    • 31
                    #24
                    I'll come back with an update on the problem with these appearing stripes. First of all, I want to tell you that we have this problem with 3 equipment respectively = C280 / C454 / C264.
                    I discovered how to cause them to appear by performing stabilization several times ... the equipment stabilizes and puts those patches several times and which the itb eraser blade cI also replaced all 4 cylinders with the same result.
                    I also put a new itb and it's the same ... stripes that don't erase. To erase these stripes, I have to use a cloth and only with it can I get rid of these stripes.
                    Only original toners were used.
                    We decided in the end to change the development modules that are on time and are relatively young as life and surprise!!! the stripes are erased!!! What do these development modules have???
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4651
                      #25
                      [ATTACH=CONFIG]56279[/ATTACH]
                      As I posted I didn't think it had anything to do with the transfer belt. But I also don't think it has anything to do with developing units. And for sure not with 3 different older models all doing same thing! Just doesn't make any sense. If all 3 machines at same location I would look at environment where located, etc.
                      Bottom line is all us technicians can keep "guessing" what the issue is but never find the real solution. Something just doesn't add up!
                      • cristachecri
                        • Mar 2015
                        • 31
                        #26
                        Yes... really the first thing was to think about the environment... but everything is ok and the temperature is constant. There are 3 different clients but the environment seems to be ok.
                        • copyman
                          Owner / Technician
                          • Sep 2005
                          • 4651
                          #27
                          I've serviced hundreds of the 3 models you listed and I've never seen it once and you have 3 machines doing same issue! This is where I would call a Priest in for an exorcism. This is so strange can only be the devils work!
                            • 23002
                            #28
                            Usually when I get three machines in the same location doing the same thing, there's an enduser involved fixing something for you. Behavior issues can be very tricky to solve. First you have to figure out what they're doing, then try to figure out how to get them to stop doing it. =^..^=
                            • copyman
                              Owner / Technician
                              • Sep 2005
                              • 4651
                              #29
                              Hey BC I was thinking that as well but OP said in his last post:
                              " There are 3 different clients but the environment seems to be ok."
                              • subaro
                                • Oct 2010
                                • 1274
                                #30
                                Does the machine put down calibration patches on both side of the belt or one side ?. I would run a calibration and stop it in the middle of it and look at the belt and see if there is patches on both sides of the belt. If one side is cleaning and the other side is not, then, why ?. There are voltage bias applied and removed during the cleaning of the belt, on a technical level of operation, if I recall correctly.
                                Some kyocera has the problem ,where the patch remains on the belt after calibration and can be seen on the paper for the first few prints. What I found was one of the contact spring that the transfer belt makes contact with on the machine [ machine side ], was out of position .
                                I found that solution here , where a poster "TMAGED" Posted that solution. So, it's worth a look to check the contacts. I don't know that machine, but the it is a weird one indeed.
