Biz 454e
  • copyman
    Owner / Technician
    • Sep 2005
    • 4712
    Biz 454e
    Hi
    Is there a soft switch or something to reset toner gauge to full on this 454e B&W model? I put a new OEM toner in early and display still has a message "replace toner when indicated". I didn't have time to run halftones to run out toner until machine stopped and said to replace.
    Firmware was just updated.
  • rrrohan
    • Sep 2011
    • 1977
    Re: Biz 454e
    dont think there is one for anything older than 8 series.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4712
      Re: Biz 454e
      Thanks, reason I asked is seem to recall a color 4 series bulletin about resetting toners all back to full? Think it might of been a firmware?
        • 23008
        Re: Biz 454e
        Just a longshot here ... is the front doorswitch being made? I had an 808 not too long ago showing "Add Toner". I changed the toner ... no change, but I did notice that the "Door Open" message did not appear when the door was open. The spring actuator for the front door switch was bent from slamming. =^..^=
        • copyman
          Owner / Technician
          • Sep 2005
          • 4712
          Re: Biz 454e
          Thanks, I will check.
          • copier tech
            • 8165
            Re: Biz 454e
            Originally posted by copyman
            Hi
            If you replaced the toners early then the gauge won't reset.
            The only way to reset the counters is remove all toners then full full bleed gradations prints then fit each toner back when prompted.
            • tsbservice
              Field tech
              • 8019
              Re: Biz 454e
              4/4e doesn't matter there is no switch.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4712
                Re: Biz 454e
                There is a F/W to reset toners. Thought I remembered seeing it. I had looked under regular FW but is was under special FW on Kon/Min dealer site.
                Here are the Color & B&W F/W's to reset toners to 100%
                Version GX7-K2
                7/20/2015 347.26 MB C224e C284e_C364e_C454e_C554e_A5C10Y0-F000-GX7-K2.exe Release Notes: bizhub C224e, C284e, C364e, C454e, C554e (LK-101) Special Firmware Version GX7-K2 Resets the value of Toner level to 100% when replacement of new toner cartridge
                SEE DLBT1501508EN01.pdf
                Version GX7-K2
                7/20/2015 346.56 MB 224e 284e_364e_454e_554e_A61F0Y0-F000-GX7-K2.exe Release Notes: bizhub 224e, 284e, 364e, 454e, 554e (LK-101) Special Firmware Version GX7-K2 Resets the value of Toner level to 100% when replacement of new tone cartridge
                SEE DLBT1501509EN01.pdf
                • copier tech
                  • 8165
                  Re: Biz 454e
                  Version GX7-K2
                  Version GX7-K2
                  7/20/2015 346.56 MB 224e 284e_364e_454e_554e_A61F0Y0-F000-GX7-K2.exe Release Notes: bizhub 224e, 284e, 364e, 454e, 554e (LK-101) Special Firmware Version GX7-K2 Resets the value of Toner lever to 100% when replacement of new tone cartridge
                  Thanks for sharing.
