Heavy scratch marks on paper
  • dxoliveira
    • Aug 2022
    • 8
    [Misc] Heavy scratch marks on paper
    Good Morning to all of you,
    Please, i need help with a konica c554e causing scratch repeated marks on paper. The marks looks like tire marks and have the same distance between then. The paper becomes smashed in the marks and no toner adesion. All colors and trays presents the same result. I visually inspected the drums, the pressure roller, 2nd transfer roller and the fuser and they appears to be with no damage on the surface despite the bad print quality. Can someone please tell me your bet, because i am totally lost in this one.
    Respectfully
    Douglas Xavier
  • copyman
    Owner / Technician
    • Sep 2005
    • 4724
    Re: Heavy scratch marks on paper
    Have you stopped paper before entering fuser to see if marks are on paper. Also check the plastic exit rollers above fuser for toner build up.
    • tsbservice
      Field tech
      • 8020
      Make one copy of blank sheet and check its back for traces like tractor tires. If they are present then check 4 black plastic rollers above fusers mentioned by copyman for toner buildup.
      Hint: scrap them hot.
      • dxoliveira
        • Aug 2022
        • 8
        I stopped the paper before the fuser and no marks. I inspected again with caution and the fuser belt was damaged, sorry for my fault. Do you know what can caise this type of damage? Looks like it was cutted.
          • 23009
          Yes, it's the fuser. The interval of repetition should be 157mm for the heat roller, or 94mm for the pressure roller. =^..^=
