C454e Missing features for public user
  • Jp2
    • Sep 2022
    • 8
    My C454e is missing features under the scan/direct input button. Any thoughts on how to get this screen to match the user guide?
    I have attached a photo of the screen
  • Synthohol
    Certified Konica Expert
    • 5838
    Re: C454e Missing features for public user
    smb scan is missing.
    does the machine have a HDD and is it enabled and working?
    • Jp2
      • Sep 2022
      • 8
      Yes, the machine has a hard drive. The hard drive is enabled and working. I can download the scanned files from the web interface or the SMB shared folder on the bizhub its self.
      • Synthohol
        • 5838
        yeah thats not scan to PC. thats whats missing.
        utility, admin, network settings, smb settings
        try..
        • tsbservice
          Field tech
          • 8019
          Hint: User box is on HDD
          • Jp2
            • Sep 2022
            • 8
            The SMB was already set up. I have attached the screen shots of the config
            Any more ideas?
            • Synthohol
              • 5838
              everything looks ok, maybe a network reset is in order?
              seen weird crap get fixed with a reset.
              • emujo2
                • Mar 2017
                • 1579
                You mention "public user" but I cannot tell from your picture that authentication is enabled. Do you mean the default scan screen is missing the SMB icon?
                1. Did it ever work?
                2. What happened just before it disappeared?
                3. Was any 3rd party app added that may have taken control of the Open API?
                There are several settings that can remove or modify what can be selected using direct input, but I can't find any way to remove just the SMB icon.
                • Jp2
                  • Sep 2022
                  • 8
                  1) It has not worked since I purchased this machine second hand.
                  2) The machine was previously owned by the government, I had to disable the piv/cac so that I could us it in my small office environment.
                  3) Unknown. The machine had the hard drive removed, I replaced the HDD, formatted the SSD, reset the settings, updated the firmware and expected that all of the original standard functions would be available.
                  I can create addresses in the address book for SMB. I can create groups and access the groups, but cannot access the member in the group that is a SMB. The machine does not allow me to choose the SMB from the scan panel.
                  I have attached screen shots of the authentication setup. very basic.
                  • emujo2
                    • Mar 2017
                    • 1579
                    next time lead with this info..
                    CAC/PIV is setup with both firmware and softswitch changes. This keeps anyone from changing anything unless they take it out of CAC/PIV mode.
                    You need to find the CAC/PIV setup instructions and change the listed items back to their defaults. It's going to be 2 softswitches and a non CAC/PIV F/W. E
                    • kingarthur
                      • 1364
                      I'm guessing that you need to use the Panel Customisation Tool, to bring back the "buttons" that are missing
                      • tsbservice
                        Field tech
                        • 8019
                        Another easy way around this is to setup scan to email and call it a day
                        Or search this forum for what Ed mentioned.
                        • Ziggy
                          • Feb 2018
                          • 761
                          Set Softswitch 12 to hex 00 and softswitch 41 to 00 and load latest base firmware.
                          • Jp2
                            • Sep 2022
                            • 8
                            emujo2 and Markks,
                            Thank you for the replies, I have tried setting all of the softswitches to match another machine and have uploaded the A5C10Y0-F000-GDS-M1(00) Firmware but to no avail.
                            I have also tried firmware version A5C10Y0-F000-GDT-M1(00). PS: The previous firmware version was A5C10Y0-0100-GDM-M1pki
                            Is there more than one firmware that I need to load or a specific sequence that I need to load the firmware in?
                            Please see the attached images for the firmware versions and softswitch settings.
                            • Ziggy
                              • Feb 2018
                              • 761
                              Originally posted by Jp2
                              emujo2 and Markks,
                              [ATTACH=CONFIG]56752[/ATTACH]
                              [ATTACH=CONFIG]56750[/ATTACH]
                              [ATTACH=CONFIG]56751[/ATTACH]
                              Try going into service mode the press stop 9 and turn off authentication wait for power cycle message after turning it off before turning off machine
