BZ958 J3205
  • tech51
    • 846
    BZ958 J3205
  • tsbservice
    Field tech
    • 7990
    Re: BZ958 J3205
    Originally posted by tech51
    Hi all.
    I have a 958 that gets a J3205 after a run of about 400 duplex prints of A4 portrait.
    The paper appears to stop in the exit area on the second side.
    I have so far replaced the exit/reverse unit, the adu assembly and the upper exit unit in the rh door.
    Its strange in that it will run 1-250 ok then the jamming starts and gets progressively worse.
    No Matter what I adjust it’s always the same.
    Has anyone experienced this?
    Any suggestions would be welcome.
    Thanks.
    Didn't had that but seems to remember member here from Australia battled something similar and it ended he/or another tech previously swapped unit from bh758 looking equal but not exactly.
    @rrrohan can you elaborate?
    Another thought: heat accumulation may contribute here for something to slow/drag enough causing timing issue.
    • Synthohol
      Certified Konica Expert
      • 5808
      Re: BZ958 J3205
      check the duplex belt.
      i added shim at bottom.
      • rrrohan
        • Sep 2011
        • 1976
        Re: BZ958 J3205
        A795R74600 ADU Assy B758
        A796R72000 ADU Assy B958
        • Ziggy
          • Feb 2018
          • 699
          Re: BZ958 J3205
          Is the motor located in the right side door with the registration unit in it?
          • Synthohol
            • 5808
            Re: BZ958 J3205
            upper right hand side when staring at door.
            • Ziggy
              • Feb 2018
              • 699
              Re: BZ958 J3205
              Do you think replacing the belt would help?
              • rrrohan
                • Sep 2011
                • 1976
                Re: BZ958 J3205
                yeah 758 and 958 taking different units
                but there seem to be so many things that can cause this jam its inlikely that in his case.
                Funnily enough 3205 jam on a C759 is my first job tomorrow
                • Synthohol
                  • 5808
                  Re: BZ958 J3205
                  the belt is fine, the plate the motor is mounted on may be skewed or bent and adding the shim changed the angle of the motor gear to pull the belt on the shaft not repel it.
