Bizhub c4050i Jam 11-02
  • Konicaboy
    • Oct 2020
    • 4
  • avecosat
    • Jun 2012
    • 304
    Re: Bizhub c4050i Jam 11-02
    I had the same problem , you need to change Conveyance / Paper feed assy AAJRR71422 I tried everything :rollers , sensors , clutch and when I changed the whole group it was solved
    • Konicaboy
      • Oct 2020
      • 4
      I already changed it from an another machine. Still the problem but i saw now theres an new part. I will try that.
      • copyrooks
        • Oct 2013
        • 208
        Try removing this rubber spacer between the feed roller on the tray itself. Had a few do the same and we threw that part away no more issues.
        • copier tech
          • 8133
          This is a known issue there's a few modified parts or just replace the modified paper feed unit.
          Countermeasure for J-1101 or J-1102 occurrence.pdf
            • 23002
            Thanks for sharing! =^..^=
            • femaster
              • May 2011
              • 1487
              [ATTACH]56920[/ATTACH]
              That's pretty interesting. In the US, they have us replacing the plastic actuators ("Stopper Part"s) with ones that are longer.
              • copier tech
                • 8133
                Ah ok thanks for sharing. Maybe that bulletin will get issued over here soon!
                • elmaligno
                  Expert technician KM
                  • Oct 2009
                  • 302
                  it is already
                  Field technician since 1994
                  • tsbservice
                    Field tech
                    • 7995
                    Hi copyrooks, can you be a little more specific, any chance you know the part number or have a picture of this spacer.
                    • KMFLT3CH
                      • May 2017
                      • 229
                      It's a tiny little black rubber O-ring in between the sep roller cradle and frame of the paper tray. Collar - 9J04534301
                      • tsbservice
                        Field tech
                        • 7995
                        Now I see it. Thanks.
                        It seems to me this machine is made of tiny little pieces of junk without any engineering tolerances in reserve, go figure 0.5mm and presto we are jammed. However this forum rules and techs here are one of the best community I've ever seen, God bless CTN!
                        • copyrooks
                          • Oct 2013
                          • 208
                          I was looking through the parts manual and its not there. When i get to my office on monday let me see if i can find one we haven't taken off yet.
                          • copyrooks
                            • Oct 2013
                            • 208
                            Found one!
                            4050i-1 hosted at ImgBB — ImgBB
                            4050i-2 hosted at ImgBB — ImgBB
                            • copier tech
                              • 8133
                              I agree, not a fan of this model. They sure look like they were made to a budget.
