FS-533 stack actuator
  • mascan42
    • Oct 2008
    • 488
    I have a machine with an FS-533 internal finisher that has managed to knock the stack actuator loose.
    Unfortunately, I can't work out how to get at this. I've managed to get as close as removing the bracket with the surface detection solenoid, but this actuator is much further inside, behind the alignment motors and gears (the motors are removable, in place, but not the gears and brackets). Has anyone ever had to remove the alignment plate entirely? I can only see the two screws on either side, but that doesn't free it up.
    • 22995
    Re: FS-533 stack actuator
    It's been a long time since I've been into the FS533, but I seem to recall entering through the bottom for that flag. I've had these stripped to the frames before. There were many updates. =^..^=
    • Synthohol
      Certified Konica Expert
      • 5958
      it can be done with forceps and spring hook tool.
      wrapping the spring is the hard part.
      • mascan42
        • Oct 2008
        • 488
        How? The mounting points aren't even visible.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4820
          If you get down to South Jersey or Phila area I have some complete FS-533 off low meter machines I'll sell you cheap.
