C454e ce301 part 2
  • adecanmin
    • Oct 2010
    • 316
    C454e ce301 part 2
    Gentlemen
    I went back to the machine. It stayed on all night. I restarted machine and it worked. It was printing and scanning. As I was getting ready to leave. The customer was getting ready to copy and it said "internal error and it will be cleared." It never cleared itself so I rebooted the machine and it was stuck on 2 shark fins and the machine was running. I waited 15 minutes still stuck. I rebooted the machine and the ce301 code came back. My question do you'll think I need to replace the mfpb, the ssd board or something else? It's strange that it worked flawlessly for about 45 minutes.
  • copier tech
    • 8156
    Re: C454e ce301 part 2
    Originally posted by adecanmin
    Gentlemen
    I've not seen your previous post but this error can be a failing HDD or CR2032 battery on the MFPB.
    โ€‹
    • adecanmin
      • Oct 2010
      • 316
      I'll check the battery voltage when I go back and maybe try a hard drive. Thanks. The service manual doesn't go into great deal about this code. I did the battery fix firmware update a month before. Hopefully it's the hard drive.
      • tsbservice
        Field tech
        • 8018
        May be SSDB as well. Easy fix if you have new one.
        • kingarthur
          • 1361
          There is a Ce301 troubleshooting guide - PSEU_BT2020155EN. let me know if you can't find it
          • adecanmin
            • Oct 2010
            • 316
            I can't find it. If you have the guide that would be great.
            • tsbservice
              Field tech
              • 8018
              I can't
              • adecanmin
                • Oct 2010
                • 316
                I only get access to the Konica site every so often. Not a dealer. I found a document from all solutions downloaded from August. It indicates it is a firmware bug. Next time I'm on the site I need to get GC3A9. Hopefully that will fix it.
                • kingarthur
                  • 1361
                  Check your PM
                  • Gift
                    • Mar 2011
                    • 2459
                    C-E301... I think that can also be triggered by bad printjobs or garbage data from network. It wouldn't hurt to test it without a network connection for some time (do test copies and print from USB / scan to USB in between).
                    I think improvements against "C-E301" are mentioned all the time in the FW change logs - don't expect too much on that end unless the installed FW is really, really old.
                    • adecanmin
                      • Oct 2010
                      • 316
                      I leaning more toward hardware. The problem didn't occur before I worked on it. I corrupted something. I'll troubleshoot in this order
                      Memory
                      HDD
                      MFPB
                      SSD/EMMC
                      • REGSIS
                        • May 2016
                        • 435
                        I agree! A bad driver can cause the mess in certain circumstances.
                        Only in one case for me it was HDD. (E301 when releasing secure print job)
